Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 06-10-2005, 04:08 PM
droptheclutch_450 droptheclutch_450 is offline
Send a message via MSN to droptheclutch_450
Question Bad Alternator? ('92 Bird 3.8)
Hey all just went out to start my car today. And the first time it started right up, took it around the block a few times, and my MIL came on, and my speedo. was kinda rocky stays at a speed then jumps up and down. My CD player was off. So I went back and parked it in the driveway, and turned on my headlights to see what would happen, and the motor acted like she was under heavy stress shaking that whole car. Then turned off the car, and turned it to KOEO (Key on engine off) and the CD player turned on no problem. But tried to start it, and got the dreaded starter click. So if anyone knows what MIGHT be the problem please let me know!
Old 06-10-2005, 06:48 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: Bad Alternator? ('92 Bird 3.8)
First fully charge the battery so that you can start the car and test the battery. A quick test is with the engine running, disconnect the Neg battery cable and if the engine quits the problem is with the alternator or regulator because the alternator. output isn't enough to power the engine electronics. Autozone can test the alternator and do a load test on your battery.
Old 06-12-2005, 12:45 PM
thunderbird muscle's Avatar
thunderbird muscle thunderbird muscle is offline
You can do a cheap test on your alternator using a voltmeter and if it is putting out around 14 volts its doing good. And it probably means battery
A founding member of HNF car club!
Do you know what it feels like to do an amazing burnout listening to that wonderful exhaust note, Oh you drive a honda sorry dude, but theres hope they still make nitrous oxide!
Racing a Honda is like being in the special olympics even if you win your still retarded!
Old 06-12-2005, 11:40 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
An alternator can supply 14 volts but not be able to handle a load. Testing an alternator with a multimeter is not accurate at all. Neither is testing your battery with one unless you can put it under a load.
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 06-14-2005, 06:11 PM
True, but if it isn't putting out 14 volts then it is not working properly, I would just take itto advance.
