Old 06-10-2005, 02:47 PM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
wat other clusters ARENT VSS
i just picked up a 92 teg cluster for $20 but i was wondering what other clusters could i use that are not VSS. if i was to get a ITR cluster.. is installing VSS gonna be fairly ez in a si tranny?
Old 06-10-2005, 04:18 PM
Re: wat other clusters ARENT VSS
not like im even gonna try to bid against those guys on ebay for any ITR -EK clusters god those shits are expensive!!!
Old 06-10-2005, 04:57 PM
Exempt Exempt is offline
Send a message via AIM to Exempt Send a message via Yahoo to Exempt
Its not that they lack VSS... VSS just means Vehicle Speed Sensor... All cars have them... The problem is that the newer cars (well, donw know about ALL cars, but Hondas) come with electronic, and our cars use mechanical VSS's to work...
That said, from my understanding, any electronic D or B VSS is interchangable... As for which vehciles have electronic vs mechanical, I have no idea without researching it... But my guess is, if the tranny is cable, its mechanical, if its hydro, its probably electronic... But this is only a guess...
I myself want to do a 00 Si cluster swap into my CRX Si... But yea, as u said, they are expensive!
Old 06-10-2005, 07:01 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
just get an electronic VSS from a 92+ dseries engine. itll bolt right in. then wire up the wires from it to the cluster of your choice. theres FAQs around telling you which wires go where on particular clusters.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 06-10-2005, 10:20 PM
Re: Re: wat other clusters ARENT VSS
[quote=Exempt]Its not that they lack VSS... VSS just means Vehicle Speed Sensor... All cars have them... The problem is that the newer cars (well, donw know about ALL cars, but Hondas) come with electronic, and our cars use mechanical VSS's to work...
wow thanks dude for the quick tutorial but neways u did answer my question about the VSS being interchangeable for my little d-series tranny
Thanks incucivic for ur reply..i know theres 3 outputs of the VSS ground-power-source and the source gets split to the ecu and cluster, so now i just gotta find a connector that will prolly end up being a bitch to find. thanks fellas
