Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 06-10-2005, 01:52 PM
donlach donlach is offline
grinding sound
I have a 2001 isuzu rodeo 4wd. I started having a grinding sound from the front driver side wheel when parking or pulling out of a parking spot. I took the car a few times to the dealer but the noise never occur during test drive. I look under the car and found the sway bar is rubbing against the shocks. Anyone with this problem?
Old 06-10-2005, 02:10 PM
rodeo02 rodeo02 is offline
Yep. Very common issue, especially with aftermarket shocks. The factory (POS) shocks have a plastic piston rod cover (instead of steel) that usually prevents the noise. Everything is a pretty tight fit on the front suspension.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 06-10-2005, 03:59 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: grinding sound
I have aftermarket monroes and they passenger side rubs a bit. I think the solution is to losen up the sway bar and slide it back over.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
