Old 06-10-2005, 01:45 PM
SidewayzS15's Avatar
SidewayzS15 SidewayzS15 is offline
Send a message via AIM to SidewayzS15
How to hookup a turbo
I looked around for about 3 days, and i finally found out how to do this. This might seem like a pointless post, but i think it will cut down on a lot of the n00bie questions. I hvae altered a picture from Scale Speed Works owner to show where the piping should go. I realize some posts similar to this have been made, but they werent very clear, i thought, and i figured id make it really clear by doing this.
Hope this helps some people!
Description: Intake is what it sounds like, you can modify the integra intake in this case and attatch it to this point. Exhaust is refering to the down pipe, which would come normally for the headers, so you add a down pipe to this port, then run that to the exhausts. Intercooler is going to the right side of the intercooler (looking at the front), then from the left port of the intercooler, you run a pipe that hooks up to the manifold(where the stock intake hooked into) After that just add some details such as brackets and fasteners for a more realistic look. Once my integra is completely hooked up and painted i will be sure to post a picture for better reference.
EDIT: Please note that the exhuast and intercooler tags are reversed
Old 06-10-2005, 01:57 PM
ales's Avatar
ales ales is offline
Forza Schumacher
Re: How to hookup a turbo
To me that doesn't look right at all. This has been discussed before, so if you do a search of the forum, I'm sure you'll find a lot of information on how the turbocharger works and what various outlets/inlets are connected to.
Old 06-10-2005, 02:01 PM
SupaMan89T's Avatar
SupaMan89T SupaMan89T is offline
Send a message via AIM to SupaMan89T Send a message via MSN to SupaMan89T Send a message via Yahoo to SupaMan89T
your intercooler should be exhaust your exhaust should be intercooler and from the intercooler the intake connects to the other side of the intercooler and your intake labeled spot would have a pipe with a filter.
Project Lexus Revive
Old 06-10-2005, 02:19 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 06-10-2005, 02:50 PM
ah well i tried, and i asked a few drifters and they seemed to agree. Delete this post then
Old 06-10-2005, 02:54 PM
pre98zetec's Avatar
you can yourself, go to edit/delete in the first post in this thread, select delete this post. and click delete and the thread will be gone.
-Josh-
Old 06-10-2005, 02:57 PM
SupaMan89T's Avatar
how about i fix it i have a pic i can post right now.
Old 06-10-2005, 03:08 PM
mighty_real's Avatar
mighty_real mighty_real is offline
Here's a better pic of how the system should look:
It's just a guide as car & truck makers design as they wish to accomodate for engine and chassis design.
Note also that there should be an air filter of some sort where in the pic it says "Ambient Air Inlet".
Note that the intercooler is always after the compressed air but before the cylinder intake (to cool the fuel/air mix). Think of an intercooler as an "in-line" device.
Also, you don't have to be pinned down to an intercooler design that looks like a radiator. My 1:1 '90 VW Corrado G60 had a cube-like intercooler tucked way in front of the left front wheel & under the battery.
John
Old 06-10-2005, 03:57 PM
OK well thanks for sending me off in the right direction. Ill keep so n00bs can find it if they search. pretty big if lol
Old 06-10-2005, 04:42 PM
bhop73's Avatar
bhop73 bhop73 is offline
Re: Re: How to hookup a turbo
Maybe you should edit your first post so the newbies don't get confused?
http://www.bhop73.com/
Old 06-10-2005, 05:53 PM
Re: Re: Re: How to hookup a turbo
good idea, ill do that now
Old 06-10-2005, 06:35 PM
nis.k.a.'s Avatar
nis.k.a. nis.k.a. is offline
nightmaR3Z
Old 06-10-2005, 07:22 PM
That re-labeled pic is much better!
You now see that you've pretty much mounted the turbo back to front as the air intake is more likely to come from the front (I'm assumimg your engine is meant for a front engine/rear wheel drive car).
Also, you could add a tubular exhaust flange (smaller in diameter than your turbo center section), a few (scale) inches long, to the exhaust snail. This is where the engine pipe would hook up (not always a gasket at this point because of extreme heat and a three-bolt flange is OK).
If you do that, you might as well tighten up the turbo center section a bit. All that it houses is a very small center shaft bearing (turning about 10x engine speed) and passages for oil and maybe water (coolant).
John
Old 06-10-2005, 07:48 PM
Jaymes's Avatar
Jaymes Jaymes is offline
I had a question, isn't the wastegate supposed to be mounted on the cool air part of the turbo instead of the hot air (exhaust side)? Since then it would be leaking out exhaust in the engine bay...
Old 06-10-2005, 08:07 PM
Since the exhaust drives the turbo, the wategate is mounted there.
On street cars, it dumps exhaust directly to the exhaust rather than driving the turbo pinwheel. It cannot dump loud, raw exhaust into the engine compartment for lots of reasons. One of which is that it still has to go through the catalytic converterter to be cleaned up.
John
