| Off-Topic Talk about anything other than cars. |
Torque specs on fuel rail
Does anyone know the torque specs for the three bolts holding the fuel rail on? I just put new injectors in and now it's leaking I checked everything else but I don't want to strip the aluminum threads...
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff. http://www.ratemydsm.com/member/ez1286/?member=ez1286
Nevermind I got em 7-9 ft lbs if anyone else needs em
Im very compfuse about those Torque( for ex
7-9 ft lbs. Do you need speacial tool too do that ?. Where to buy them? thanks.
Re: Torque specs on fuel rail
Just a torque wrench. Google torque wrench to see the different types--they're cool tools
1996 Eagle Talon |
Just a quick comment on this topic. No matter how tight the rail is, it has nothing to do with the sealing of the injectors. The lower seals and upper orings take care of that. Its not like a HG or a water pump gasket where clamping force is required for sealing. So that's why the torque value is so low. Its just to locate the rail and keep it from falling off. I just wanted to point it out for the newer guys, since knowing these basic fundamental concepts can make figuring things out on your own a little easier, take some of the mystery out.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
