Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 06-10-2005, 11:50 AM
ztxt ztxt is offline
Xterra 2000 emission failure CO too high
Hi guys,
I am a newcomer of this forum. I need your help! My xterra 2000(88K) is a nice car but I failed the CO test is very high, can't pass the emission inspection. I have changed the air filter,spark plugs and wires the whole set. Problem still there. Do you have any ideas about the CO problem?
Thanks
ztxt
Old 06-10-2005, 12:50 PM
OffroadX OffroadX is offline
Send a message via AIM to OffroadX
Re: Xterra 2000 emission failure CO too high
Is your "service engine soon" light on?
Old 06-10-2005, 01:23 PM
paul89se paul89se is offline
it's probably an oxygen sensor.
Old 06-10-2005, 01:59 PM
Re: Re: Xterra 2000 emission failure CO too high
No, other things just work normal.
Old 06-10-2005, 07:38 PM
today I went to check the oxygen sensor and knock on sensor, the technician said that there is no code for the oxygen sensor, even one of the sensor did not respond the to engine very well. But there is a code for knock on sensor, but the guy told me it was only a minor problem no need to change it.
What shall I do? To change sensor one by one n finally figure out the CO problem? Any suggestions?
thanks
Old 06-11-2005, 11:26 AM
Knock sensor is not a problem, as you can see, it isn't even enough to trigger a code on is own, and Nissan's system doesn't even rely on it for normal operation. Look elsewhere.
Old 06-18-2005, 01:37 PM
corbinwaterski's Avatar
corbinwaterski corbinwaterski is offline
It's probably your catalytic converter.
WAR UTAH!!
