Old 06-10-2005, 11:29 AM
escort0526 escort0526 is offline
it's never died before, I'm worried
Today driving to work I stopped at a light with the a/c on and the car stumbled and died. It's never done that before, not a peep out of it for almost 160k. It started right back up and seemed fine the remaining three blocks into the garage at work, but naturally I'm worried. what should I look at? No codes in computer, no check engine light nothing seems amiss, am I being paranoid? It's a '93 lx wagon.
Old 06-10-2005, 11:41 AM
frafreg frafreg is offline
Re: it's never died before, I'm worried
Don't worry yet. I have had cars do the same thing to me after filling up with gas, never to have it happen again. With no codes in the computer and no check engine light on, look for the obvious things under the hood and on the guages. Things like loose belts or wires under the hood or guages reading abnormally. I look under the hood of my car probably 4 or 5 times a week just to make sure everything is okay. Its a good habit especially when you have high mileage. Hope this helps.
Frank
Old 06-11-2005, 03:43 PM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
could it be the a/c compressor is getting ready to die? my escort really bogs down when I run the a/c too. when was the last time you tuned it up
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 06-12-2005, 10:54 AM
The car is tuned every april 1st, that's the day I bought it, I figured I'd remember to do it that way. The air conditioner...well that's a different story. It's never been touched. Still blows 38 degree air, so I figure if it's not broke don't fix it.
Old 06-14-2005, 08:48 PM
Arnoldtheskier Arnoldtheskier is offline
Hi..when you say "no codes in the computer"..there are 2 kinds of codes.A temporary "soft" code..that will erase itself in about 90 starts IF it doesn't happen again.AND a hard code.BOTH these codes can be pulled and looked at.IF you do pull a soft code..erase it..and sortta check it out..DON'T be concerned over it.Don't be taking stuff apart or replacing stuff.Escorts like good plugs and wires.1 stall..I wouldn't worry.Could of been anything.I too have a 93 Lx wagon.STILL cold air.LOL I am right now in 90 degree HIGH humidity sortta shopping around for a deal on 4 snow tires for it for next winter.The wagons also LIKE 4 similar tread pattern tires..with some grooving..for snow/slush..
