Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 06-10-2005, 09:55 AM
RobF RobF is offline
Very high Idle 99 Passport
My 99 Passport had idle problems. I was told to replace IAC valve, but when I replaced it, veh. now idles around 4000 RPM! Can't seem to get it down, except by unplugging IAC, pulling plunger out and reinstalling it, but leaving it unplugged. When I do this, it idles low, but surges up and down between 500-1200 RPM. Help! Anyone have any ideas?
Old 06-10-2005, 10:11 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Very high Idle 99 Passport
most likely the intake manifold gasket. a very common problem.
see the FAQ's for more info.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 06-16-2005, 03:48 PM
Re: Re: Very high Idle 99 Passport
Ok,
I replaced the IAC valve, and the PCV. Engine idles at 2000- 2500 RPMS steady, with no surging. CEL says P0507. Is it possible I got a bad IAC? Any way to test this to see if it is working? Do you think this still could be the IMG?
Old 06-16-2005, 04:03 PM
marcre's Avatar
marcre marcre is offline
Send a message via AIM to marcre Send a message via MSN to marcre Send a message via Yahoo to marcre Send a message via Skype™ to marcre
I would definately check the IMG. To me at least, it seems like everyone has similar problems when they go bad, but there are also differences as well. Whenever there is a problem like you are experiencing it is good to check the IMG first, since it is a known issue. Your idle issue is what leads me to believe this is your problem.
When my IMG went bad the codes were pointing me in all sorts of directions. After spending several hundred dollars in repairs, I looked at the IMG. That was the culprit. The Rodeo has been running smooth ever since. I just wish it didn't like drinking oil on occasion.
Marc
2007 VW Jetta 2.5 5sp
1999 Rodeo LS 3.2 4x4 SOLD, but not forgotten
My Rodeo
Old 06-16-2005, 04:21 PM
Thanks Marc-
Do you know of any specific tests I can perform (resistance, voltage checks, etc.)? I just spent $60 on a new one from dealer and want to make sure it is working. I thought it was odd when I unpackaged it, removed the clip holding the pintle in, and it did not spring out. Not sure if it was supposed to, but assumed so because of the spring clip.
Old 06-16-2005, 04:23 PM
Re: Re: Re: Very high Idle 99 Passport
Originally Posted by RobF
Thanks Marc-
Oops... I thought you said IAC I am going to try the carb/ brake cleaner test tonight on the IMG.
Thanks!
Old 06-16-2005, 04:39 PM
marcre's Avatar
It is possible you got a bad IAC, but I am not sure how to test it. Remember though, with the IMG and the carb cleaner test, it is not guaranteed to work. It may not, but I suspect with the problems you are having it will.
Hopefully someone else will chime in about the IAC.
I am not an expert when it comes to auto repair, but my IMG gave me so many problems, I feel I know them inside out.
Marc
My Rodeo
