Old 06-10-2005, 09:00 AM
bigry2004 bigry2004 is offline
Send a message via AIM to bigry2004
AC question
[97 LT 4X4 150k miles]
I recently had a heater core replaced on my blazer. however, i dont know how that affects the AC. When turned on, it has good pressure, however the air does not get as cold as it should, even when turned all the way to the "cold" side. What are some possible causes for this and maybe even possible solutions? Thanks
Old 06-10-2005, 09:04 AM
TonyMazz's Avatar
TonyMazz TonyMazz is offline
Re: AC question
Maybe low on freon...
1999 Blazer LS 4WD 4.3L "W"
2004 Silverado 2500HD Duramax
Old 06-10-2005, 08:29 PM
rksnc's Avatar
rksnc rksnc is offline
Send a message via AIM to rksnc Send a message via Yahoo to rksnc
Re: AC question
You need to get pressure readings. Without them you are flying blind.
Old 06-11-2005, 10:15 AM
Re: Re: AC question
hmm... so, whereabouts could i go to get this done?
Old 06-13-2005, 01:00 PM
rksnc's Avatar
Re: AC question
Find someone with a set of gages. Or you need to take to mechanic. The readings tell you everything that is going on with the system.
Old 06-14-2005, 04:57 PM
anyone know how much freeon is a gallon?
Old 06-14-2005, 05:09 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: AC question
a gallon???
You only need 32 ounces to completely fill an empty system.
Old 06-15-2005, 11:27 PM
Re: Re: AC question
Originally Posted by blazee
a gallon???
oh ok, i wasnt sure because someone mentioned they thought a place charged like $35 plus the price of freeon used and i thought he said per gallon but i guess i was mistaken. thanks though!
Old 06-18-2005, 03:37 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: AC question
It is not Freon, it is R134A.
Go to AutoZone and get one of the recharge bottles with the gauge.
Start the truck, put the temp to cold, the fan to high and the controls to MAX AC.
Charge from the low pressure connection port and release the charge can to get a reading from the gauge.
Use the Measure & Charge from Interdynamics
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 06-18-2005, 11:49 PM
Re: Re: AC question
okay, thanks. what will this tell me? and where is the low pressure connection port?
Old 06-19-2005, 12:42 PM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
Re: AC question
The low pressure port will be located on the side of the silver looking can under the hood. In my truck, it's on the passenger side. (An older '95 Blazer) It will have a cap on it that you twist off, looking like a bigger version of a tire valve. You cannot accidentally hook up a refill bottle/gage/hose to the high pressure side, it simply does not fit. For reference, the high pressure port is on the lower return line between the bottom of your silver can (dryer/accumulator) and the side of the A/C compressor.
