Go Back   Automotive Forums Car Chat > Subaru > General Discussion
Old 06-09-2005, 11:10 PM
Doug_I Doug_I is offline
stripping 87 XT turbo 5-speed what do youu need
1987 Subaru XT 1.8 Turbo full time 4WD
with factory-installed A/C and 5 speed transmission
Interior parts are light grey, exterior color is red unless noted
This car has been stripped to the bone, and all parts are ready to go.
Located in Poughkeepsie NY 12603.
Which is the Mid point between Albany and New York City.
Whenever possible, electrical parts will be rechecked upon inquiry.
All parts are original Subaru parts unless noted.
Everything is sold as is...Condition will be noted in text, and pictures when necessary.
xt61991 Posted: Wed Aug 17, 2005 7:41 pm I just recived the turbo off of doug. It was great dealing with doug, very prompted. Thanks
Description Price
BODY Parts
  • factory Sunroof panel (has a few small dings) it has 3 small dings from the inside. $35.00
  • Right side fender $30.00
  • Left side fender $30.00
  • Right side door shell $50.00
  • Left side door shell $50.00
  • Right side window regulator $10.00
  • Left side window regulator $10.00
  • Right side door glass $15.00
  • Left side door glass $15.00
  • Left side mirror power ( Koito $25.00
  • Right side mirror power ( Koito $25.00
  • trunklid with luggage rack (has shallow dent on backside could be poped out from inside) $40.00
  • Trunk hinge assembly $10.00
  • Turbo hood has minor surface rust on the inside, and some key scratches on the outside ( not down to the metal) $50.00
  • 16 chrome lug nuts $7.00
  • Gas cap/ Fuel Tank Cap non-locking United States use Stant cap #10825 or 10595 Fits Year: 1987-> $5.00
INTERIOR
  • front roof trim (between sunroof and windshield) 94031GA630 $7.00
  • Right headrest (fabric on the rest of the seats are ripped) $10.00
  • left headrest (fabric on the rest of the seats are ripped) $10.00
  • SOLD Glove box door with lock $15.00
  • Trim panel around steering column $10.00
  • Left side door panel $15.00
  • Right side door panel $15.00
  • trim panel where back seat locks in 94032GA190 $7.00
  • SOLD right side power window switch assembly (black) 6ZT $5.00
  • Steering column $30.00
  • Control center (above radio) $10.00
  • AM/FM Cassette Radio/Equilizer ( few knobs missing) $20.00
  • Rear deck board with speaker covers $12.00
(Parts underlined are from the center console)
  • Differential lock switch $5.00
    SOLD 2 cover plates $0.75
    SOLD coin holder $0.75
    SOLD 3 cover plates to cover screws on sides $0.75
    console lid with hinges $7.00
    push button release for console lid $1.50
LIGHTING
  • 2 license plate lamp assemblies $5.00
  • Cyclops brake light assembly $10.00
  • backup light panel Kotto 132-20340 $40.00
  • 2 washer squirter for headlight R&L $5.00
  • Motor for headlight washer $10.00
  • Right side front directional light $7.00
  • Left side front directional light $7.00
  • Right side front directional light ( in bumper cover) $7.00
  • Left side front directional light ( in bumper cover) $7.00
ELECTRICAL
  • OEM Battery cables with boots $10 pair
  • Windshield wiper motor assembly $30.00
  • Right side power window motor $30.00
  • left side power window motor $30.00
  • flasher relay $5.00
  • External air temp sensor inside Right fender $7.00
  • windshield washer sqirter motor $10.00
  • 2 relays 4 pin l l 056700-5500 relay B4 12V 15A $7.00
  • 3 relays 4 pin -- -- 056700-5260 12V 22A 12F24 $7.00
056700-5260 Headlight Relays The 3 horizontal arranged relays are on top of the fuse box. The relays (fuel, ignition and blower fan) are above the fuse box and vertically arranged. Remove the panel under the dash and steering column, the relays you are looking for are behind the 'tray' box. The blower relay is the third from above with the colorless plug.
  • black box 84055GA000 6 pin
ENGINE COMPONENTS
  • SOLD turbo
  • SPYDER intake $100
  • throttle body $25.00
  • Ignition Coil Borg Warner E520 $15.00
  • electric cooling fan $20.00
  • Clutch fan assembly 320-12-1 (no play) W/ air cond.factory-installed A/C Year: 5/1986 -> $40.00
  • Distributor assembly 22100-AA400 D4P86-03 7201 $75.00
  • pressure plate, clutch plate, throw bearing $30.00
  • Air Filter $2.00
  • rear dog bone motor mount $15.00
  • mass airflow sensor ( mounted on air box) 22680 AA110 A36-000 R00 7109A JECS $25.00
  • Transmission mount $30.00
  • Clutch Cable $10.00
  • 4 fuel injector assemblies (specify front, rear, right, or left) $25.00
  • fuel pressure regulator $27.00
  • Starter Mitsubishi type mit70381 #23300A $75.00
  • Alternator Hitachi LR165-704 $75.00
  • 5 speed manual transmission full time 4WD $300
BRAKES AND SUSPENSION
  • auxiliary brake valve (sits under master cyl) $15.00
  • set of 4 subaru alloy rims with tires
  • Tires are decent exept one has some dry rot from going flat over the winter $300 set
  • (3 line) master cylinder (needs rear seal) 33-50 Nabro 13/16 resiviour L14 $10.00
  • Front right brake caliper $25.00
  • Front left brake caliper $25.00
  • Front right brake hose $5.00
  • Front left brake hose $5.00
  • Front right brake rotor $10.00
  • Front left brake rotor $10.00
  • front and rear air adjust lines compressor and tank $30.00
  • vacuum line from brake booster $5.00
  • right front air adjust strut $50.00
  • left front air adjust strut Front right axle Assembly $25.00
  • Front left axle Assembly $25.00
  • Front right hub $15.00
  • Front left hub $15.00
  • Front right ball joint $10.00
  • Front left ball joint $10.00
  • front right regulator for air struts $7.00
  • front left regulator for air struts $7.00
  • front right regulator cover for air struts $3.00
  • front left regulator cover for air struts $3.00
Misc
  • 87 XT owners manual in the blue vinal Subaru case $5.00
Below is my ongoing project AND IS NOW FOR SALE a 1957 LLoyd 600 body on a 64 International scout frame.
