Old 06-09-2005, 10:29 PM
justinmikehunt justinmikehunt is offline
90 Lumina Euro Turn Signal.
I have a 90 Euro Sedan, and my left turn signal stays solid. I've determined that it's the front left corner bulb that needs to be replaced, but I can't figure out how to get to it. I removed some bolts that make the light kind of turn, but that's all I can find.
Any help would be appreciated.
Old 06-10-2005, 08:25 AM
Manny_boy's Avatar
Manny_boy Manny_boy is offline
Re: 90 Lumina Euro Turn Signal.
Did you check your flasher? Usually if your signal does not flash but stays solid, that is a malfunctioning flasher.
To remove your front corner turn signals (IIRC) you have to remove the headlight, which will reveal the mounting bolt.
Old 06-10-2005, 09:17 AM
The one bulb in the front left does not light, while the others stay solid. Bulbs staying solid is also a sign that one is blown, which one is.
But how do I check my flasher?
Old 06-10-2005, 12:18 PM
Manny_boy's Avatar
I know that works for the new electronic flashers, but unless you've upgraded your Euro, you have the old kind (the silver round one). To test it just, swap your hazzard flasher with your turn signal flasher and see if it acts the same. They are both the silver round type.
Old 06-10-2005, 03:03 PM
and where is the flasher located?
Old 06-10-2005, 03:13 PM
Manny_boy's Avatar
Your turn signal flasher is located near the base of your steering column on the right side. Just follow the steering column to the firewall and look up. your hazzard flasher is on the passenger side under your dashboard lower cover.
