Old 06-09-2005, 09:04 PM
wdy wdy is offline
no airconditoning
Could someone help me out? I have a 97 s-10 with a 4.3, the air conditoner stopped blowing cold air. The compressor kicks on for
about 5-10 seconds then shuts off for about the same amount of
time. I got a gauge on the refridgerant and there is the right amount of
pressure. It does blow slightly cooler but not by much.Any help would be appreciated.
Woody
Old 06-09-2005, 11:05 PM
JMouse JMouse is offline
what is the pressure on the and the high side, and what is the temperature the day you check it. out side temp effects the pressure. if it falls below 20 psi the low pressure swith will shut off the compressor. and if the high side pressure goes above 350 psi or so, it will also shut down the compresssor. typicaly when the compressor cycles," runs for a few seconds and shuts off" the refregerant is low, because the low pressure switch is cycling.
Old 06-10-2005, 07:19 PM
wdy wdy is offline
Re: no airconditoning
The temperature outside was around 90 degrees, I'm in PA. The gauge I have came with the can of refridgerant and only fits the fill valve, I think that is the low side.
Woody
Old 06-11-2005, 06:36 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Re: no airconditoning
Yes, what is the low side pressure?
Old 06-11-2005, 07:07 AM
wdy wdy is offline
Sorry I thought I had the pressure in the first post.
The pressure reads 30 to 50 psi, it varyies as the compressor turns on and off. thanks
Woody
