Old 06-09-2005, 08:34 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Thumbs down Belt problem
Hey guys.
I got my underdrive pulley installed a couple months back. About 2 weeks after the install, the belts started to squeak. I've tried tightening the belt (the alternator, power steering...) using the tension pulley located in the front of the engine bay with no avail.
I took in the other day to get my mechanic to fix it. He took out the cruise control, wedged the alternator, and tightened the bolts up. He also sprayed the belt with some oil or WD-40. It was beautifully quite. About 4 hours after that, I went out, and the belt started squeaking again. Not as bad, and not as constant. Now, it's back to the same squeaky as before. I tried spraying it, but that didn't work.
The tension pulley located at the front of the engine bay is missing the bolt that adjusts the tension. The bolt that goes through the pulley is there and nice and tight. Could this be causing the problem? Do I need a bolt in there to help it hold better.
Car is NT. Thanks for your help.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 06-09-2005, 09:02 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: Belt problem
That would be a good place to start....also when you say it's tight... how tight? tight to me is the belt won't turn more than 1/4 turn...
What belts are being used? Are they the stock belts or other...
I had problems with a squeeky alt. belt when I changed it out but with one from autozone.... it squeeked after a few weeks.... I went to dealership and bought an OEM belt and had NO problems after that....
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 06-09-2005, 10:58 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Why the hell is it that the belts on DSM's squeal so fucking much? I hardly ever hear any other car have a squealing belt, unless its a pile of shit that isn't taken care of.
These are not just single incidents. I think mitsubishi made some shitty tensioners or something, because this type of shit always happens.
I still have not been able to get the squeal out of my car, and its really bad when its humid or wet outside. Let us know if something works.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 06-10-2005, 10:12 AM
RSLaser RSLaser is offline
Im having the same problem with an aftermarket belt for my alt, its probably too tight but im hoping ill stretch it a bit. Anyway, try using some silicone lubricant spray, sprayed on the belts while the car is running. Rule of thumb, you can tell which belt is squeeling by when you shut the car off its hot to the touch.
1991 Plymouth Laser RS
Only sat for a few years....
Old 06-10-2005, 01:10 PM
nova1313's Avatar
nova1313 nova1313 is offline
Re: Belt problem
same problem belt squeel here. Just turn the stereo up another notch it's amazing the squeel goes away
08 Kawasaki Ninja 250R - Plasma Candy Blue
07 Toyota Rav4 - Ltd Ed. 6 Cyl AWD
97 Mitsu Eclipse Spyder GS-T 5 Speed
Old 06-11-2005, 03:56 PM
david-b's Avatar
Dave is THAT guy
Re: Belt problem
The stereo is a good start, but it's annoying when pulling up to someone to race... "Hey man, your cars making funny noises..." Assholes.
Anyway, I even tried spraying it again, and its not working. They are brand new belts! Goodyear, I think. IDK what to do.
75 Monte Carlo
Old 06-11-2005, 04:21 PM
SmicAA72
Guest
Posts: n/a
Re: Belt problem
the spray i use works nice... its like stp belt spray, i picked it up in autozone, works like a charm....
Old 06-11-2005, 06:17 PM
Prime First's Avatar
Prime First Prime First is offline
Send a message via AIM to Prime First
Re: Belt problem
Exactly. The squeal that my belts make when it's wet/humid outside is just too damn annoying. And my mom's Galant squeaks too Anybody got any other solutions? I'll have to check out that STP spray that Smic is talkin about
Prime First
1999 Mitsubishi Eclipse
10th Anniversary Edition
Old 06-11-2005, 06:36 PM
Re: Belt problem
That spray will NOT help.... maybe for a few days or weeks if your lucky....
As I posted earlier... try going to the dealership and getting an OEM belt... I did and my squeels went away!!!
Old 06-12-2005, 01:58 PM
Re: Re: Belt problem
Good advice, spyderman. How much did that cost you? And what causes the squeal to come back after the spray?
Prime First
Old 06-12-2005, 02:23 PM
Re: Belt problem
I have tried two different types... and each time it helped for about a week and again the squeeels came back... Now this is from a brand new belt from autozone... I also tried different tensions on the belt... If you do a search this topic HAS been discussed a few times... hmmm the search function, why would someone use that? There are a few of the VERY knowledgeable people here who have said what I posted earlier in this thread...
Use the OEM belts and it will help ALOT. DSM's do have the problem of belt squeel, maybe just its trade mark noise... I don't know.
If your being a dick and contradicting me about the spray fine.. be that way. I am just trying to pass on my own findings along with others. If ya don't like it and/or don't agree with it... to fuckin bad.
To answer your question of "what causes the squeal to come back after the spray?"
I don't really know for sure... what I do know is that it is a compound that kinda softens the belt giving it more grip... I used to use it on my RC car tires for more traction when racing... cheaper than the "tire compound" and worked just as good.
When the belt squeels it heats it up and glazes the contact surface... I/myself.. have found it is just a temporary fix for an ongoing problem... just spend the $13 at the dealership for an OEM belt and try it out for yourself.... That's my 2cents
Old 06-12-2005, 02:34 PM
What the hell did I say to offend you? I was just trying get a simple answer to a question. You think me complimenting you on a good post is being a "dick head?"
Prime First
Old 06-12-2005, 02:38 PM
Re: Belt problem
sorry... I guess I took it the wrong way the way it was worded....
If ya asked about the price of a belt from the dealership... about $13... maybe it was $16... anyways.. worth the $$...
The spray was just a waste of money....no matter what ya pay... lol
Old 06-12-2005, 02:43 PM
Thanks, that really was great advice. I was about to get the spray, but I'll just go to the dealership. Do they put it on for free?
Prime First
Old 06-12-2005, 02:50 PM
Re: Belt problem
lol.... no unless ya know them... really good...
Belts on a 4g63 arent that hard to do... the only crappy thing I found was between the wheelwell shroud and the pulley. kinda a tight fit... go go gadget arms... lol
