Go Back   Automotive Forums Car Chat > Mercury > Villager
Old 06-09-2005, 07:20 PM
roberte roberte is offline
Timing Belt Replacement
What's involved with changing the timing belt on a 2000 Villager??
Anyone had it done at a dealership,if so, what was the cost??
Can a DIY person with a good mechanical background accomplish this task???
Is there a lifetime guarantee belt available for purchase??
Old 06-30-2005, 05:04 PM
IH8SPM's Avatar
IH8SPM IH8SPM is offline
Re: Timing Belt Replacement
Why do you want a lifetime belt? They are good for about a 100k and then they need to be replaced. I drive about 36k a year and change it every 90k except for the first time I went to 120k gotta love factory installed.
Old 06-30-2005, 06:33 PM
What I really wanted to know was if this is a job a DIY person can do or if you had it done at a dealership and what the cost was to have it done !!!
The reason I ask about a lifetime belt was because I put a lifetime Goodyear Gatorback serpatime (?) belt on my Dodge Cummins Diesel and it's guaranteed for a lifetime. It also stops the squeak or squeal sound on shutdown.
Old 06-30-2005, 11:27 PM
Ranga Ranga is offline
Hi,
My neighbor has a 1998 villager and last month he had installed the timing belt himself. It took him about 4hrs , but he seemed to have managed it fine. I spoke to him about that as I too have a 2000 villager and one of these days might have to change the belt. He said that he needed a crank pulley puller and that was the only special tool that he needed. He just bought a shop manual from the dealer for help. He put the passenger side of the car on a jack stand and after removing the front wheel was able to do the job.
As regards cost of doing the job, I checked with a local mechanic who had been doing most of the work on my other cars, and he said that it would cost me around $ 250 + a little more if the water pump was to be changed also. The dealership might charge a bit more. I live in Dallas/Fortworth. TX.
Hope this helps,
Ranga.
Old 07-01-2005, 10:22 AM
IH8SPM's Avatar
Yes it is a do it yourself project if you are mechanically inclined and have some type of haynes manual or a shop manual to guide you in the right direction. You will need the pully puller or some home made type like my mechanic made a special only for vullagers using some of the screws he purchased from the dealer. I paid $150 for labor including the antifreeze. The belt was a gator belt and a ebay water pump for $10 I think. There should really be no extra labor since the pump is right in front of your face and can be removed very easily. Good luck.
Old 07-01-2005, 06:30 PM
Thanks for both of your replies. That was the information I was looking for. Thanks again.
