Old 06-09-2005, 04:02 PM
kingpinn's Avatar
kingpinn kingpinn is offline
his will fit
a d16a6 header will fit a d16z6 and y8 or any other d series right same for all mods wright like cams and all. the reason i ask is just because i didnt no if vtec messed anything up with the parts swap
"Much to success to ya, even if you wish me the opposite;
Sooner or later we'll all see who the prophet is" Nas
Old 06-09-2005, 04:09 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: his will fit
well vtec cams wont work too well in a non vtec motor... but other than that, the rest should fit.
Old 06-09-2005, 04:40 PM
skotman's Avatar
skotman skotman is offline
i don't understand what the question was.
Old 06-09-2005, 04:53 PM
Kven's Avatar
Kven Kven is offline
Re: his will fit
hes basicly just asking if parts from different d-series motors can be interchanged.
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
Old 06-09-2005, 07:10 PM
SiZ's Avatar
SiZ SiZ is offline
Re: his will fit
Ya, cams are major. As far as external stuff goes like intake/exhaust its the same.
Old 06-09-2005, 09:22 PM
kingpinn's Avatar
Re: his will fit
good to know thanks guys ..
Old 06-10-2005, 10:53 PM
kingpinn's Avatar
Re: his will fit
what about a clutch will a act clutch for a ex 5th gen tranny fit the 4g si tranny
Old 06-10-2005, 11:03 PM
SiZ's Avatar
SiZ SiZ is offline
Re: his will fit
No.
Cable - hydro
Old 06-11-2005, 12:38 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: his will fit
actually depending on the tranny, it will. i think its the 90-91 DX and Si trannys that use the sameclutch disc as the later hydo trannys. i know for a fact that the input shaft on the 88 base model is smaller than the input shaft on the 91 DX and Si, cause i tried putting a DX trans in one of my STD cars, but didnt have the cash to get another clutch disc. needless to say i had to wait until i could swing the price of the new disc.
i even used a flywheel from a 91 DX on a 98 EX once, and it bolts on the same, and the pressure plate from the EX worked too. the owner broke the ring gear off the flywheel and it made the starter just free spin the ring gear. so i put a 91 DX flywheel in it, and everything bolted up.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 06-11-2005, 06:34 AM
Sikocivic's Avatar
Sikocivic Sikocivic is offline
Re: Re: his will fit
The 88 tranny has a different # of splines on the imput shaft. You can use that tranny on any D series motor if you use a 88-89 flywheel and a 88 disc.
You can use any 89-00 tranny on any 88-00 motor. You just have to match the clutch to the correct flywheel. So if you want to use a 92 or newer ACT clutch on a 89-91 motor and tranny just use the 92 and newer flywheel and you are good to go.
90 Civic Si Turbo ZC
Old 06-11-2005, 04:52 PM
kingpinn's Avatar
Re: his will fit
should i just but the whole ex tranny in my rex
Old 06-11-2005, 08:38 PM
Sikocivic's Avatar
The 92 and newer trannys are "hydro" trannys. You need to use a 88-91 "cable" tranny in your CRX.
And please learn to spell so we can understand what you are saying
Old 06-11-2005, 11:07 PM
kingpinn's Avatar
Re: his will fit
sorry that my spelling wasnt perfect for your highly anticipated post once a year !!!!!!
other then that thanks for the help
Old 06-12-2005, 06:53 AM
Sikocivic's Avatar
I would rather post once a year and be right, than post all the time and be wrong
