Old 06-09-2005, 11:09 AM
phideltkuntryboy phideltkuntryboy is offline
Send a message via AIM to phideltkuntryboy
Battery contacts corroded
my positive terminal of my battery keeps getting corroded. i cleaned it once cause it was corroded and a month later it was corroded again. Could i have a leak in my battery?
Old 06-09-2005, 02:00 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Battery contacts corroded
Probably a bad battery. Replace it.
Old 06-12-2005, 12:06 AM
xtrememeasures10 xtrememeasures10 is offline
Send a message via AIM to xtrememeasures10
Re: Re: Battery contacts corroded
Battery Terminal corrosion, all Corrosion b/t two dissimilar metals, is actually caused by four things. take away one and corrosion cannot form.
Anodic Metal
Cathodic Metal
Electron Flow
Water
Of course you cant remove the anodic or cathodic metal because thats your battery terminal post and the terminal clamp.
Nor the electron flow because w/o that you wouldnt start your truck.
Clean it off with some battery terminal cleaner from the auto parts store, NOT COKE! then coat it with Fitting grease. That will separate the moisture from the terminals and you shouldnt have to worry about it.
However if It develops under the grease you may have battery acid seeping up.
