Old 06-09-2005, 09:38 AM
Dakota88 Dakota88 is offline
starter motor replacement
Need to replace the starter motor on my 1992 Taurus wagon. Beginning to think the engine must be pulled first. Anyone got any tips?
Thanks.
Old 06-09-2005, 10:22 PM
gbic1 gbic1 is offline
Are you sure this is a Taurus? You take one ground wire off with a nut then 2 bolt through belhousing and maybe on rear support bolt and the cable. That is it. Should not take more than an hour.
1967 cougar 390 FE in progress
1993 F350 Crew Cab 5.8 111K
1983 Coachman 23ft class C 460
1988 Bronco 351 C6
1964 Galaxie 428 4sp project
1995 Mustang 3.8 Auto
1966 Mustang Fast back Project
1994 Tracer Trio 1.9
1968 F250 Camper Special 390
Old 06-11-2005, 10:31 PM
jmas jmas is offline
I did a '93 3.0L and it was not a difficult job. 2 Bolts hold the starter to the engine. The Battery Cable & the Solonoid wire have to be removed also. It was recommended to me not to use the existing push on soloniod connector again. Too many problems. Splice a quality high current disconnect into the line & shrink some tubing over it. The Starter Motor cost me $80 from a local Rebuilder.
Old 06-12-2005, 09:06 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: starter motor replacement
Thanks.
I replaced the starter motor on my '93 Taurus SHO in the Autozone parking lot. Took a floor jack, jackstands, and about 45 minutes. Have some metric sockets and extensions handy, get underneath the front of the car (after disconnecting the battery!) and it should be obvious what needs to happen. Like others mentioned, there are about 2 wires (nutted on to the starter) and two bolts holding the starter to the bell housing.
I had to do the one on the SHO twice in the same day. The gear on the solenoid had the wrong number of teeth. I ended up swapping the original onto the new starter assembly and it worked fine. If you can afford a day or two without the car, I would recommend having a local automotive electronics rebuilder rebuild the starter for you. You're likely to get better parts than getting a rebuild unit from a large chain parts store.
-Rod
