Back Panel Removal
How do I remove the panels in the back of my 2 Door 99 Blazer LS?
I think my back passanger side speaker may be loose and want to tighten it up. Im sure it is what is causing the bad rattling noise I am getting from the panels. Also, does anyone have any other panel noise making fixes they would like to share? |
Re: Back Panel Removal
I had to rattle proof my truck a while back!
I removed almost all the panels and added wheather strips under each pannel. It worked perfectly!
94 Blazer S-10 1st Gen-4wd 4.3L W V6 Faster and louder than stock, but nonetheless a blazer! |
That's great. So how did you remove the back panels? And what kind of stripping did you use?
Unfortunately I haven't seen the inside of a 99LS, But I'm sure someone in this forum could answer that for you.
I know with mine, a few of the panels covered screws holding others panels up. I used something similar to this stuff. ![]() You can get it at any hardware store, cheap! It works really well!
94 Blazer S-10 1st Gen-4wd 4.3L W V6 Faster and louder than stock, but nonetheless a blazer! Last edited by Sen Sen; 06-09-2005 at 10:54 PM. |
Just thought I would update and let anyone that cares know how I fixed the noise coming from the panels.
Removed the panels and then where the panels clip, took 3M double sided tape and ran it on the edge, used a knife to cut a slot for the clips to slide into as well. Put the panel back together and no more noise. The inside of the cab has never been this quiet since I bought my Blazer. Very impressed! |
What did you use to pop the clips off on the panel? This is one of my projects too!
A soft cloth over a flat head screwdriver..just pushed in a bit and popped it up.
