Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 06-08-2005, 11:16 PM
crazyclimbr crazyclimbr is offline
? how to remove brake light bulb
2003 4 Runner with a left brake light not working. There is a small access panel that I removed and then disconnected the plug from the light but I cannot figure out how to pull the bulb. I tried to twist and then just pull on it but nothing. I'm hesitant to use a lot of force for fear of breaking something. Anyone know how to do this?
TIA Steve
Old 06-09-2005, 12:16 AM
blazzingbrandon blazzingbrandon is offline
Send a message via AIM to blazzingbrandon
Re: ? how to remove brake light bulb
well, the bulb probably isnt greased, so thats why its so hard to get out. i suggest that you just pull as hard as you can or wiggle to see if it will move. also, try a tiny screwdriver to pry it off with, whats the worst that can happen? its already blown right. and when u put the new bulb in, put light bulb grease so this wont happen a second time.
Old 06-09-2005, 01:29 AM
I should have said the plastic piece that holds the bulb instead of the bulb. I'm going to try it again and just pull harder. Maybe use a pr. needle nose to get a grip on it.
Thanks
Old 06-09-2005, 08:22 PM
Goatwater Goatwater is offline
try pushing in then turning anti-clockwise and then pull.
Old 06-09-2005, 08:31 PM
good idea i hadn't thought of that.
