Headliner Help
well like every headliner mine started sagging and it wasnt to bad untill I couldnt see out hte rear window. So Im going to replace it with a custom one and I was wondering how do I get the headliner out? the whole thing not just the fabric. Im planing on a black with red trible design. any help is welcome!! and plus at like $50 to do it myself or have a shop do it for at leasts $300 on a high schooler's budget I have to do it myself
94 Camaro Full roof V6 |
Re: Headliner Help
couldn't tell you exactly how on a '94. What I can tell you is that the surrounding trim will have to be removed (front?, back, sides) and after that you should be able to see how it is held in place.
Just stick some pins in it.
I was going to replace mine, but the board the fabric is glued to, is coming apart. The cheapest I could find a new board was 150 without the fabric on it. I decided it wasn't worth it. I'm not 100% on this, but I think you just take off the dome light and the plastic trim peices. Just crawl in there you should be able to find it.
![]() Quote:
I tried pins but since I dont have A/C they just come out (ok so I have 275 A/C but thats why the pins come out)
Re: Headliner Help
Yeah, it's not a nice feeling to have your headliner teabag you. I have really short hair, like marine boot camp short when it first gets cut, and mine still touches me.
I think you can just get some spray adhesive and it should hold.
1994 Camaro V6 A4 - RIP 3/1/06 ![]() http://www.cardomain.com/memberpage/805164 1994 Camaro Z28 A4 - Bought 4/6/06 |
Re: Re: Headliner Help
- Jason 1995 Pontiac Firebird ![]() ![]() User Guidelines | VB Codes Explained | AF Merchandise "Each of us, is in the scheme of things, insignificant. But millions of insignificant people, doing a tiny bit, can add up to be a very significant force." |
I have all the stuf to fix it I just need to know how to remove the trim
Re: Headliner Help
the trim on any vehicle is held on by trim screws and retaining clips. Just make sure you have all of the screws out of the panels that you are removing and give them steady pulling pressure to remove them. It is easier to wiggle the panel and look for spots in the panel that looks reinforced ie; the panel tries to bend up to a certain point and where it isn't moving, that is where your retaining clips are. Just pull on them and they will pop off.
If it bleeds, kill it! If it has sirens, outrun it! If shes hot, ride her! |
