Where to mount trans. oil cooler
I deceided to purchase a Hayden trans. oil cooler for my 1998 Dodge Durango with the 5.2 engine. If I just mount it in front of the radiator and AC condensor, won't there be a problem with those devices in cooling. Will the engine possibly overheat, or maybe the AC won't cool as it should ?
Re: Where to mount trans. oil cooler
ok, there are 3 cooling sistems in the front, the A/C high press coil (front), the trans cooling sys coil(midle) and the cooling sys of the engine, you can install it in the midle. Now that you are installing the new coolin sys for the AT, clean the coils with a special liquid for that job, and you will increase the efectiveness of the coolin sys for the A/C, engine and surely the trans.
Tell me when you do the job. Good luck. |
Re: Re: Where to mount trans. oil cooler
I just put mine in the very front, in front of the ac and the radiator. works just fine. |
