Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-08-2005, 10:20 PM
funk06 funk06 is offline
Send a message via AIM to funk06
Clutch Friction Point
Recently I've noticed that the friction point in my 94 laser keeps moving farther and farther up the pedal. Now its to the point where im almost off the pedal before the car has started moving. DO i need a new clutch? Or do i need to adjust my pedal? BTW the fluid level is fine. PLEASE HELP!!!
Old 06-08-2005, 11:20 PM
GSXracerGuy GSXracerGuy is offline
Send a message via AIM to GSXracerGuy
Re: Clutch Friction Point
That's actually one of the major signs of crankwalk. Your car is so old anyway that the chances of you having crankwalk are very low. My friend's car had your same problem; he ended up needing to get a new pressure plate.
1995 GSX M/t 87k[IMG][IMG]
Gotta lotta work to do.
[IMG][/IMG]
