Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 06-08-2005, 07:29 PM
woodzie2 woodzie2 is offline
Question 01 altima ac leaks inside
i have an 01 altima and whenever the ac is on it leaks condensation onto the passenger floor??? help its driving me nuttss
Old 06-08-2005, 11:02 PM
JustSayGo JustSayGo is offline
Send a message via AIM to JustSayGo Send a message via Skype™ to JustSayGo
Re: 01 altima ac leaks inside
There is a drain hose where the condensation should drip outside. If the hose gets plugged, condensation builds up until it leaks on the inside. Open the hood and look on the passenger side firewall for a rubber boot with a 90 deg bend. It is directly above the pass side steering boot. Make sure that the boot isn't plugged and is pointing toward the ground.
Old 06-10-2005, 09:28 PM
Re: Re: 01 altima ac leaks inside
i found the boot but what is the proper way to unclog it? i tried with an air hose to back blow it to no affect, does this hose have a clamp on it on the inside where it connect to the unit?
Old 06-15-2005, 03:15 PM
Brotherssis Brotherssis is offline
Re: Re: Re: 01 altima ac leaks inside
I had the same thing happen to my 2000 altima and it ended up ruining the computer chip from the water dripping. Be careful!
Old 06-15-2005, 04:51 PM
Re: Re: Re: Re: 01 altima ac leaks inside
Using compressed air or a wire like an old coat hanger or solid copper wire left over from a household wiring project can work to open the restriction. The problem is if you can't remove the stuff that is blocking the hose, very often it will quickly plug again.
