Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 06-08-2005, 04:58 PM
Pont69conv Pont69conv is offline
2001 Window problem
I was driving the car and my son rolled down the rear driver side window. Afterwards it would not go back up. I first checked all of the switches. This was not the problem. After that I took the door panel off. Once inside I replace the module. The window would still not work. I then ran a battery to the window motor and the window went up. then when i unpluged the extra battery the window rolled down powered by the car but again would not go up. Has anyone any experience with this problem or have any idea what it could be?
Old 06-08-2005, 07:31 PM
randman1's Avatar
randman1 randman1 is offline
Re: 2001 Window problem
It doesn't go up when using either the master switch or the specific door switch?
Old 06-12-2005, 06:30 PM
markwb's Avatar
markwb markwb is offline
When you operate either switch at the drivers door or locally, do hear a faint click noise coming from the right rear door?
Mark
2003 Pontiac Bonneville SSEi, 1999 Ford Escort SE, 5 Speed
IBEW Local 261 Groton, CT
Old 06-13-2005, 05:29 AM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Sounds like one of your switches is stuck in the down position.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 09-22-2005, 02:23 PM
Yes i am hearing a faint clicking sound inside the door. Any idea what that is?
Old 09-22-2005, 03:27 PM
markwb's Avatar
Re: Re: 2001 Window problem
Sorry, I meant left rear door. The faint click that you hear is the left rear door module switching power & ground to raise or lower the window.
You mentioned that you replaced the module, is that the control module? If you connected a battery direct and operated window in raise & lower, then it sounds as if the problem is with the power between the module and the drive moter to raise the window.
Mark
