Old 06-08-2005, 04:42 PM
TeameXcessive TeameXcessive is offline
89 civic seat bracket help!
hey ya'll
i have a aftermarket racing seat and i can't find the bracket for a hatch. i try to use the original bracket, but it's way off after i install i on the seat. i think i might have to drill a hole on the floor of the car. i was wondering if it's worth it. let me know whatever u guys can help me.
peace,
Old 06-08-2005, 08:25 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: 89 civic seat bracket help!
for mine, i bolted the rails to the floor, and then put the seat on top to line everything up. then i simply made two pieces of plate metal strips that connected one rail to the next, and bolted the seat to the strips.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 06-09-2005, 11:24 AM
Re: Re: 89 civic seat bracket help!
so do i have to drill any holes? how do you connect the metal? Did you just drill a hole and connect them with the bolts? Thanks,
Old 06-09-2005, 12:24 PM
EF You's Avatar
EF Life Giver
yeah, thats all i did. i drilled holes in the brackets i made, and used nuts and bolts to attach them to the rails. then i centered the seat, marked it, and drilled holes. then bolted the seat to the brackets with the supplied allen head bolts for the seat
Old 06-09-2005, 02:00 PM
Oh okay, thanks for the help. I appreciate it. i will try it when i get home. do u know where i can get the metal thou?
Old 06-09-2005, 07:20 PM
EF You's Avatar
EF Life Giver
i got mine from a friend who welds, he has some scrap aluminum and stainless steel.
