Old 06-08-2005, 04:06 PM
geerox geerox is offline
Voltmeter Question HELP Please???? 1997 Z-71
My voltmeter usually reads a little over the 14 volt mark. Started going to the left a little bit which seemed odd, so I took the battery and had it checked and yep it was bad. Bought new battery, but still having the same problem. Took the alternator off and had it checked today. They (Alternator Specialist, NOT Advance or the other one--the Zone one. LOL), said it was fine. I cleaned the battery contacts and the belt is fine. Can ANYONE gelp me?? The truck runs just as good as it ever has, but that guage has never fell below the 14 volt mark. Thanks in advance!!
Old 06-08-2005, 04:45 PM
Austin8214's Avatar
Austin8214 Austin8214 is offline
Re: Voltmeter Question HELP Please???? 1997 Z-71
DON'T worry about it. Check the out put at the battery with a multimeter as long as you get 14 volts there you are good to go. The meters on the dash are not trust worthy.
Old 06-08-2005, 08:02 PM
I checked it at the battery, and I got between 13 1/2 and 14 .
Old 06-08-2005, 08:08 PM
2000CAYukon 2000CAYukon is offline
I would check the battery cable connections at the block and starter. It might be a good idea to check their resistance to see if it is too high.
I have also heard that the wire at the back of the alternator is too small and can overheat. Take a good look at that wire.
//2000CAYukon
Old 06-09-2005, 01:13 PM
Austin8214's Avatar
Then you are good to go.
Old 06-09-2005, 10:19 PM
silveradoman silveradoman is offline
The only time you should change the battery is if you get 11 volts, in winter that is enough to leave you stranded
Old 06-09-2005, 11:11 PM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
when a engine is running you should get between 13 and 14 volts. but if your not getting that then either the alternator is not charging or the battery is going bad.
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
