Old 06-08-2005, 04:00 PM
351wStang's Avatar
351wStang 351wStang is offline
Impeller speeds
Ok, I have a Vortech S-trim with a max impeller speed rating or 50,000 rpms. Right now I have a 8" crank pulley and a 2.95" pulley on the charger. According to Vortech's calculator I will be hitting the max speed of my impeller at about 5,300 rpms. I'm running a F303 cam with Edelbrock RPM heads and was planning on spinning this motor up between 5500-6000 rpms. So, since I dont have an engine dyno and a bunch of 8 rib pulleys to swap on and off I'm not sure where my shift point will be. So I figured I would comprimise and shift at say... 5,700 rpms. I'm guess this would be a pretty good shift point. So at 5,700 rpms with my current pulleys my impeller will be hitting speeds of about 53,000+ rpms. I'd like this charger to last until I decide to upgrade. So.. I can swap to a smaller 7" crank pulley or a bigger blower pulley. I played around on Vortech's calculator and ended up with this. My 8" crank pulley and a 3.15" blower pulley at 5,700 rpms will be spinning my impeller up to about 49,950 rpms.
What do you guys think? Am I cutting it too close? I know 1 good over-rev would send my impeller to the moon. Am I going in the wrong direction here? Any other option or advice? With my current pulleys Vortech told me I would probably see around 12-13 psi at about 6,000 rpms. Now with a bigger/slower pulley on my supercharger what kind of boost do you think I will see? 10lbs? Thanks in advance for the advice!
1969 Cougar
357w & TKO - 475hp
Old 06-09-2005, 09:44 PM
hustler8225 hustler8225 is offline
Re: Impeller speeds
have no clue!
Old 06-09-2005, 10:11 PM
351wStang's Avatar
Re: Impeller speeds
Well for those interested, I was told at the corral that I would be fine with the pulleys I've got. They said that I could spin higher than vortech's 50,000 rpm rating without issue. Also once you consider belt slip (8 rib) I should be in the safe zone. With 0 slippage at 6000 rpms I would see about 56,000 rpms with my current pulleys. Even after belt slippage if I over spin the impeller it will only see those really high rpms for a fraction of a second.
1969 Cougar
357w & TKO - 475hp
Old 06-09-2005, 11:04 PM
351wStang's Avatar
Re: Re: Impeller speeds
Originally Posted by hustler8225
have no clue!
Dont post if this is the only kind of thing you have to say. I saw a similiar post of yours in another thread. However, thanks for the bump.
1969 Cougar
357w & TKO - 475hp
Old 06-09-2005, 11:29 PM
Simioh's Avatar
Simioh Simioh is offline
Send a message via AIM to Simioh Send a message via MSN to Simioh
Re: Impeller speeds
LMFAO!!! yeah, he posted the same bs on my thread, its funny, i guess he has nothin better to do
Old 06-13-2005, 05:18 PM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: Impeller speeds
Look at those head lights on your car, need to polish them up
On my old Stang, I had the same pulley set up, she will slip a little, but that is not the issue. The rating is more for the effcience of the charger, so you will just be making a little hotter intake charge, if my memoery serves me right. On ebay, they sell those bracket tensioners, you might invest in one of those.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 06-13-2005, 07:28 PM
351wStang's Avatar
Thanks for the reply Skyline. Ya I'm just gonna replace the headlights lol. As far as the intake temp goes, what do you think about a water injection kit? Also I'm still looking for brackets period. Several people have offered to sell me their front plate because they are upgrading. Should I just buy a bracket from Vortech with the 1/2" front plate from the start? Do you know if the mounting holes on the front plate are what need to be modified to lower the headunit on my 351? I'm thinking maybe just redrill the holes in the front plate where it bolts to the mounting bracket on the head. Also how was your altenator relocated? Thanks.
1969 Cougar
357w & TKO - 475hp
Old 06-15-2005, 12:14 AM
SkylineUSA's Avatar
Re: Impeller speeds
I really dont know the way to do a 351W, other than getting the plate, and putting it up to the 351w block, and start modding it. As for the Atl, my stang was already set up when I got it, so I am not sure what braket they used for that. If I still had my Stang, I could tell ya.
Old 06-15-2005, 03:31 PM
351wStang's Avatar
Re: Impeller speeds
Just bought a Vortech bracket assembly from a guy at the corral. It has an alt stay bracket or something like that on it. If all else fails I'll just mod my A/C bracket and put the tensioner between the alt and P/S pump going down the drivers side.
1969 Cougar
357w & TKO - 475hp
