Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 06-08-2005, 03:47 PM
ittme ittme is offline
Where to run power wire for amp???
Getting ready to install some subs, but I cannot seem to find a nice place to run my power wire, remote wire, and rca's.
Any suggestions/pictures would be greatly appreciated.
Thanks in advance,
Ryan
Old 06-08-2005, 11:09 PM
Bodyshield Bodyshield is offline
Re: Where to run power wire for amp???
in my towncar, i just ran it along the carpet, wedged in, u wont be able to see it, and when u get to doors, take off the step molding (plastic piece or w/e it is) and run it under that then screw it back on (i think it has screws), i have a ps2 in the center console, but try to avoid running entirely under the carpet cause its a B---- to seperate from the foam underneath
Drift Clubs
www.driftclubs.com
96 tahoe baby blue LT 4x4
Old 06-09-2005, 04:23 PM
maintainin76 maintainin76 is offline
Re: Re: Where to run power wire for amp???
I agree, run them under the step moldings. ALSO, do not run the power and the RCA wires together. The power wire could possibly interfere with the rca wires causing whine. Run them down opposite sides of the vehicle.
Old 06-09-2005, 08:29 PM
Any good spots to run the power wire into the cabin from the engine bay (battery)???? I'd hate to have to drill my own hole and install my own grommet. I am kind of lazy. Pictures would be greatly appreciated.
Thanks again,
Ryan
Old 06-10-2005, 08:10 PM
i didnt feel like hassling with it so i ran it along the door and underneath the seal on the top part of the tahoe where the hood and sortof the front windshield meet because the firewall was so far down in the engine and hard to access
Drift Clubs
www.driftclubs.com
Old 06-10-2005, 11:31 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
That's usually a recipe for disaster. I always try to run it inside the OEM gromet where the main harness is. If your vehicle is within about 8 years old, you should be able to do that. If not, I'll drill a hole then run the wire through the hole and put wire loom around the hole. Then, I use window calking to seal it. Not silicone but the gooey stuff that never really dries. Some people call it dum dum
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 06-10-2005, 11:43 PM
djkurious djkurious is offline
Running the wire through the door is a fire/ shortage waiting to happen. There is a place on the left side of the tahoe for the wire topass through the engine compartment to the inside. I have a 2-gauge wire going through it! Remember, what ever side you runn the power wire on, the rca cables need to go on the opposite side!
Old 06-11-2005, 10:54 AM
i know where the grommet is, but i found it was too hard to try to get it through there, esp trying to access it through the engine bay size, because all the "pieces" from the engine are in the way, any recommendations?
Drift Clubs
www.driftclubs.com
Old 06-13-2005, 02:27 PM
TTT.
I tried looking for the passthrough on the drivers side, but had no luck finding it. Anyone have any more specific information on where exactly to look for the grommet???
Any pictures would be greatly appreciated.
Old 06-16-2005, 04:41 PM
djmann02's Avatar
djmann02 djmann02 is offline
I ran my power wire through the firewall just to the right of a power harness. If you climb under the dash and look, there will be a circular cut out already there backed with foam. Pull that off and there will be a "safe" area for you to drill a hole into the firewall. You will be clear of any obstructions(brake booster, etc) to drill and run your wire. Hope this helps.
Old 10-18-2005, 10:12 PM
homie774899 homie774899 is offline
I Just Ran My Wiring Under The Frame. Drilled A Hole Under The Back Seat And Popped Right Under The Engine
Old 10-28-2005, 09:36 AM
TRANSFORMDEZIGN TRANSFORMDEZIGN is offline
I ran mine through the firewall at the steering column grommet, then straight under the carpet.
