Old 06-08-2005, 02:53 PM
accuracy11 accuracy11 is offline
Angry major problems help!!!!
ok ladies and gents.. i went to go start the crx today and its turning over but would not fire up... i have a fields svafc so i pulled it out of where i mounted it and the car started up... but as soon as i started driving it it keeps wanting to kill itself... so i don't know where to go from there. anyone have any advise???... this prob just started today.
Old 06-10-2005, 09:46 AM
Re: major problems help!!!!
so what no one has any idea in here.. common peeps you guys have helped me before on some probs..
Old 06-10-2005, 12:24 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
possible main relay. lay under the dash, and turn the key to the on positition. if you hear the main relay click once, you are fine. if it clicks a lot of times, or not at all, you need to change the main relay.
also, turn the key on and listen for the fuel pump. its under the car, right under the back seat.
if the pump comes on, and it still wont start, pull a plug wire and ground it to the valve cover with a screwdriver or spare sparkplug. if its not sparking when you crank it, start hunting in the distributor for the loss of spark.
let us know whats up after you try these things
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 06-16-2005, 11:56 AM
ok everything you said checked out... so the car take a few min to start but it will finally start ... i removed the svafc cause i thought that was the prob but now when i start driving the car with hesitate really bad and try to kill itself ... i am totally lost on what the prob could be... could it be the injectors?... about 4 months ago i replaced the cap plugs and wires so i don't think that could be the prob... any ideas?
Old 06-16-2005, 12:02 PM
EF You's Avatar
EF Life Giver
the main relay is a tricky beast. sometimes it works, and sometimes it doesnt. usually it screws up when its hot in your car. my guess is still on that
Old 06-16-2005, 12:33 PM
how can you tell if that need to be replaced??.. how much does one of them cost?
Old 06-16-2005, 03:31 PM
EF You's Avatar
EF Life Giver
well, does the car start fine sometimes and not at all other times? does it start fine, but not run worth a crap sometimes? that pretty much the only way to know if its the relay.
if you take the relay out, and try supplying 12 volts and a ground to the feed, and it doesnt click over, then its bad. but if it does click, it still might be bad. they tend to screw up when they get hot.
also, it might be clicking on and off normally, but the pin in it that supplies your fuel injection system with 12 volts might be faulty
im not sure how much they cost, but NAPA carries them.
Old 06-17-2005, 01:33 PM
i checked the ecu and it gave me 2 codes 22 and 7 ...i fixed the 22 code cause i did not connect the vtec oil pressure switch so thats done... but i still have code 7 (tp sesor).. would that be a prob?... what exactly does the tps fuck up when its bad??... and i know you just can't replace the sensor you have to replace the whole t/b ,,... could that be the prob??.. or should i still get the main relay?
Old 06-17-2005, 01:47 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
You can replace a TPS. Just lightly tap a few slits in the rivets and turn them counter clockwise with a flathead screwdriver and the sensor will pop right out...
2008 KIA Spectra5 SX
2010 Honda CR-V EX
