Old 06-08-2005, 03:47 PM
ChrisB-98GrandPrix ChrisB-98GrandPrix is offline
Autotap software
Hello all,
Wondering who out there has used the Autotap program for Windows? I have done several mods to my 98 GTP and I want to prepare to do more. I obviously have concerns about KR and want to learn more about fine tuning things to get the most out my investments.
One question I have is with the "Generic Parameters", do these include the amount of KR? I don't see that listed on their web site. Do I have to purchase the "Enhanced GM Parameters" to get that? I think it's an additiona $99 for that which does make a difference.
Any and all replies are welcome. I am a network engineer so the computer/software side of this is no problem but the car specific issues are what I am weak on.
Thanx all and keep up the great forum!!
Chris B
98 GTP
3.4" pulley, DHP v1.0 PCM, Thrasher CAI,
TOG Headers, Random Tech Hi-Flow Cat,
I-Win 1.9 rockers, 90# valve springs, 180 Stat,
Autolite 104 plugs, TB spacer, Poly Motor mounts
Gatorback SC belt
Old 06-09-2005, 08:09 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Autotap software
Originally Posted by ChrisB-98GrandPrix
Hello all,
The answer to your question as to whether you'll need the Enhanced GM Parameters is yes. There are about 5 - 6 additional parameters in the enhanced GM module which will then allow you to place an indication on the virtual display for specifically KR (knock retard). It will be displayed in degrees. The generic will tell you if you have a knock sensor or control circuit problem but thats it. The enhanced also reads out GM specific DTC error codes such as P1XXX which may be more beneficial for troubleshooting.
BTW - You don't have to be a rocket scientist to be able to use Autotap.
Thrasher CAI, DHP v1.0 ECU,
3.25 SC pulley, CAIT GMAF, Hi-Flow CAT,
u-bend delete, 160 TS,TB spacer,
MSD 8.5mm wires, Autolite 104 spark plugs,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
Timeslip 08/12/06
AF Community Guidelines
Old 06-09-2005, 09:23 AM
BNaylor's Avatar
BTW - I forgot to mention here are the additional parameters for KR in the Enhanced GM module:
Knock Retard
Knock Sensor
Knock Sensor Active Counter
Knock Sensor Minimum Learned Noise
Knock Sensor Noise Channel
Knock Sensor Voltage
Knock/Octane Adjust
Timeslip 08/12/06
Old 06-09-2005, 06:08 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: Re: Autotap software
Knock Retard
Knock Sensor
Knock/Octane Adjust
Bob, your getting good at making list. And they are so straight too!!!
Great job. Only kidding.
Old 06-09-2005, 10:02 PM
BNaylor's Avatar
Re: Re: Re: Autotap software
Hey, just trying to help out a fellow GTP owner. The list goes on and on. You know I've only used my Autotap program twice last year and that was to troubleshoot a MAF sensor/CAI problem.
Had to loan my laptop computer to my son at college but he just brought it back to me during his short summer break. You know come to think of it, I should check my KR on the GTP since I put that 3.25 pulley on. Later Jim.
Timeslip 08/12/06
