Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 06-08-2005, 12:21 PM
knot2kwik knot2kwik is offline
02 sensor question
Where is the 02 sensor ona 2001 ranger, v6?
I now it should be on the intake manifold. I know when I changed one out on my old dodge truck I had to have a special socket for removal abd installation. Do I need any special tools for this job?
Any help is greatly apprieciated
John
Old 06-08-2005, 02:53 PM
rivguy rivguy is offline
Send a message via Yahoo to rivguy
Re: 02 sensor question
there are 4 o2 sensors on a v-6 ranger in that year - but they are located in the exhaust not the intake
-=-=-DANE-=-=-
Old 06-08-2005, 08:58 PM
rodeo02 rodeo02 is offline
Re: Re: 02 sensor question
Yep, you will have 1 upstream and 1 down stream of the catalytic converter for each cylinder bank. Your check engine light will light if you are having a problem with one of the 4. The downstream O2 sensors do nothing but tell you if the cats are working or not.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 06-09-2005, 10:44 AM
2000mudder's Avatar
2000mudder 2000mudder is offline
just rember to replace ALL OF THEM at same time for best performance!!!! you should replace at 60,000 miles.
Old 06-09-2005, 03:05 PM
is a special wrench or socket needed for removal?
Old 06-09-2005, 09:12 PM
You gotta be kidding ! They can be over $100/ea for tons of newer vehicles today, plus the downstream O2 sensors do absolutely nothing for fuel trim calculations, they just indicate if the cat(s) are working or not. On a 1998+ (OBDII) vehicle, dont throw money at new O2 sensors unless you have a check engine light in regards to an O2 sensor issue.
G/luck
Joel
