Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 06-08-2005, 12:20 PM
timguyli timguyli is offline
Radio has poor reception
My radio has the worst reception, I checked all wires and connections, and am wondering if maybe the antennae itself is bad. I was told its located in the roof area. Has anyone changed it?? Thanks
Old 06-10-2005, 05:43 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Radio has poor reception
I would say the antenna is the problem with your vehicle. I would replace it with an external antenna
that is mounted on the side of the fender or even in the roof for that matter. You should get much better reception and it would be a lot easier to install than to fix the one in the roof.
Old 06-10-2005, 07:08 PM
Thats what I was thinking, But has anyone done it? Does the Plastic body panels make a difference? Thanks..
Old 06-10-2005, 09:56 PM
cdru's Avatar
cdru cdru is offline
Isn't the antenna embedded in the glass of the windshield towards the top?
Old 06-11-2005, 10:47 AM
Pontiac Guy
I had a Lumina van that had a fender antenna and I had absolutely no problems with the radio reception. The body panels on it were plastic on that as well.
Old 06-11-2005, 10:51 AM
CDRU, No, the glass has metal flakes in it to block some of the heat from entering the huge expanse of glass area. The antenna is mounted along the roof above the headliner..Hence the reason im balking at replacing it..
