1999 4.8L - Hard to start, rough idle, reduced gas mileage:
I'm sure this one comes up all of the time, can someone suggest where to start looking:
Background: 1999 Silvy w/ 4.8L V8 - 88,000 miles No check engine light or anything like that. Symptom 1: Have to crank the engine a bit to get it to fire (used to fire right up on first crank) Symptom 2: Often, the engine will die right after firing, unless I rev it with the gas pedal. Have to do this for a couple two or three cycles before the engine settles down to a stable idle. Symptom 3: The engine idles pretty roughly. I wouldn't say its misfiring, but it's definitely shuddering. Symptom 4: Gas mileage has fallen from 18-20 average to 14-16 in the same period of time. Symptom 5: Immediately after starting truck, especially cold, I get real jerky starts that don't feel 100% associated to a sticky TB I am also suffering from a sticky gas pedal / throttle body, and with the information learned from other threads here, I'm considering trying to clean it myself. I know these symptoms can indicate a number of unrelated problems, so what I need help with is formulating a step-by-step plan of attack that goes from cheap fixes and follows with more money... (I'm super broke right now...) What I was thinking: 1. Clean the throttle body (FREE) - I read somewhere here that a varnished TB could cause similar symptoms related to jerky starts/ 2. Replace the fuel filter (it's never been replaced) 3. Spark plug/wires? 4. Do I need an oxygen sensor? What else can I check and clean that might lead to some relief? Any clues as to where to start and where to go will be greatly appreciated. Thanks in advance, Bob |
Re: 1999 4.8L - Hard to start, rough idle, reduced gas mileage:
could be just the coolant temp sensor or the egr valve. Does it run ok when it warms up?
Once warmed up, the truck runs fine except for the rough idle, which is all of the time. When the rpms are higher, the engine is smooth enough. Also, the hard-to-start problems happen regardless of whether or not the engine is warmed up and regardless of the outside ambient air temperature.
I have never noticed a change in the behavior of the engine temp guage. What is the EGR valve, where is it, and what does it do? What is the maintenance of this item? |
Re: Re: 1999 4.8L - Hard to start, rough idle, reduced gas mileage:
On my friend's '99 Silverado 4.8 it was the fuel pressure regulator.
As a check, we removed the vacuum line and fuel dripped out. It's located on the driver's side fuel rail. |
Thanks! |
