Old 06-08-2005, 07:54 AM
metallica21156's Avatar
metallica21156 metallica21156 is offline
ATF in a C4 tranny and leak
what kind of ATF should I use in a C4 trany? should I use Dexron 3 or type F? i put dexron 3 in it so i could move it and it leaks more then it did before. it used to leak from where the shifter went in and that doesn't leak any more but on the back of the tranny on the passanger side theres some kind of thing that looks like it screws into the tranny. it has a hose attached to it. its leaking from there as well. any ideas?
95 jimmy. Vortec V6. 4.3 liter CPI. ,2.5" catco cat, 2.5" cat back with flowmaster muffler split rear., 40 street series, 2 12" audiobahns in custom box,K&N CPI intake system.
71 Mustang coupe- project car. stock 302 with Cobra intake, holley 650dp, afco racing radiator, headman headers, msd distributor, 2.5" from the headers.C4 tranny with shift kit, Mach 1 body lay out.
90 cav, 2.2 tbi, gas getter.
99 chevy s10 zr2, 6" lift, duel exhaust. 5 speed.
Old 06-08-2005, 04:38 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: ATF in a C4 tranny and leak
Type F
1969 Cougar
357w & TKO - 475hp
Old 06-08-2005, 10:13 PM
what should i do if i put dexron 3 in?
Old 06-08-2005, 10:28 PM
351wStang's Avatar
Is the C4 a stock tranny out of an older car? If so what year? You may loose a tranny. I dont know if dex III and type F are compatible or not.
1969 Cougar
357w & TKO - 475hp
Old 06-09-2005, 07:58 AM
its a stock tranny from a 71 mustang. it seems to drive ok. i haven't really driven it that far though. when i got the car a few months ago the guy said to use dexron 3 in it. i changed the shifter seal monday and when i got it back togather i put 6 quarts of dexron 3 in it.
Old 06-09-2005, 05:03 PM
351wStang's Avatar
Well if thats what he has been running in it I wouldnt change anything.
1969 Cougar
357w & TKO - 475hp
