Old 06-08-2005, 12:11 AM
Metro Mighty Mouse's Avatar
Metro Mighty Mouse Metro Mighty Mouse is offline
JDM Motor swap/no power
95 1 L 5 speed-My original motor lost compression in #3 cyl and broke the timing belt when it stopped. I bought a JDM motor from a co. in New York. I swapped more than I really wanted to (stupid swift square cogs on the timing gears). I did a full tune up, cap, rotor, bosch platinum plugs, plug wires. When all was said and done (anyone else have to force engine and tranny to mate up) I have very poor throttle response and it seems to be running a tic hot. I can't find any vacuum leaks, anyone have any other ideas?
Old 06-08-2005, 09:06 AM
mickkey3rd mickkey3rd is offline
Hi MMM
I have never had to force the engine and tranny together. I do know that the clutch must be perfectly centered. The little plastic alignment tool furnished with the clutch kit has to much slop in it. This may be why
you had to use force to mate the two.
As far as throttle response goes, have you done a compression check on the engine?
I also switched all temperature components from my old engine... fan switch, temp. sender, new thermostat(make sure bleed hole is mounted on top).
Interesting I did the boiling water test on the three thermostats I have
and found that the aftermarket thermostat opened sooner than the OEM thermostat. About 10 degrees before.
Best of luck
Joe
Old 06-09-2005, 05:13 AM
barteldt barteldt is offline
Send a message via AIM to barteldt Send a message via Yahoo to barteldt
Re: JDM Motor swap/no power
check your map sensor i had to rev mine up till i realised i hooked up the wrong vacuum line
