Go Back   Automotive Forums Car Chat > Toyota > MR2/MR-S
Old 06-07-2005, 08:24 PM
turbotoyota turbotoyota is offline
what's wrong
Hey, I have a 91 MR2 turbo with an HKS Hi-Power exhaust, k&n filter, greddy intercooler, and run 14 psi with the greddy profec b spec II boost controller. I also replaced the cap, rotor, and wires with toyota parts and replaced the plugs with NGK's. I just did a compression test and each cylinder was around 185. The problem is I only run low 15's in the quarter mile. Any suggestions on why that is?
Thanks in advance
Old 06-07-2005, 09:12 PM
JekylandHyde's Avatar
JekylandHyde JekylandHyde is offline
AF - Advisor
Re: what's wrong
What rpm are you shifting at?
What's your 60' time?
What's your mph at the end of the track?
Sponsorship: Amateur Motorsports <-- Get the book! - books are now available for shipment
Old 06-07-2005, 09:19 PM
I shift at 5500
60' was 2.057
mph was around 89
Old 06-07-2005, 09:30 PM
AF - Advisor
Re: what's wrong
You should redline 1st ... 5500 is about right for the CT26 turbo for the rest of the gears.
Your 60' is fine. It is possible to nail a 1.8 or 1.9 with a stock MR2. It takes practice and you may want to drop your rear tire pressure depending on what you had them at.
Your mph is very low for your level of mods which means you are down power. What did you gap the plugs too? What octane fuel are you running? What elevation was the track at? How hot was it outside?
Old 06-07-2005, 09:43 PM
the plugs were gapped at .28
i run 93 octane fuel
I'm not sure about the elevation but I think it's low
the temperature was about 78 degrees
Old 06-07-2005, 10:31 PM
ac427cpe's Avatar
ac427cpe ac427cpe is offline
Miata is always the answe
Send a message via AIM to ac427cpe
Re: what's wrong
How fast do you shift? What kind of tires do you use? How is your alignment? How heavy and what size are your rims and tires?
hello, i am Dan
No more project cars. I wonder how long that will last...
Old 06-07-2005, 10:47 PM
I try to shift as fast as I can. The tires are some kind of Firestone something, not sure. I bought the car from an older man who wasn't using it for any kind of racing so i'm sure they aren't the best performance tires. Haven't had the alignment checked but the car drives as straight as can be with no unusual tire wear. I still have the stock 14 inch wheels and stock tire size.
Old 06-08-2005, 05:40 AM
AF - Advisor
Re: what's wrong
I sure hope you mean he gap was .028", not .28"
Elevation, temps and fuel check out.
I don't think tires are the issue since you managed a very respectable 2.0 in the 60'
Somewhere, somehow you are down power.
Do you have excess weight in the car? (like an extra 200 lbs of stereo equipment or something?)
Old 06-08-2005, 06:31 AM
sorry, I did mean .028"
The only modifications that I have done to the car have been the performance mods. The only additional weight in the car would have been me and the spare tire. I weigh 165 lbs and I wouldn't think the spare tire would slow it down that much.
Old 06-08-2005, 07:46 AM
AF - Advisor
Re: what's wrong
No, the spare and your body weight are not a big deal. I just wanted to make sure you did not add a 100 lbs of subwoofers and 15"s
So, we are back to your car being down power.
You should be easily trapping well over 90 mph, so something is up.
Old 06-08-2005, 02:26 PM
allen4000 allen4000 is offline
Is your clutch slipping?
Old 06-08-2005, 04:19 PM
No, the clutch grabs like it should
Old 06-08-2005, 07:06 PM
ac427cpe's Avatar
Re: what's wrong
is your suspension still good?
hello, i am Dan
Old 06-08-2005, 08:12 PM
Re: what's wrong
yea the rear end plants on take off with no wheel hop
Old 06-08-2005, 08:22 PM
drazhartd drazhartd is offline
Re: Re: what's wrong
you ARE driving an mr2 right?
91 MR2
Looking for Sparco steering wheel, or Momo Jet (black) wheel. Email pics, let's make a deal!
