Old 06-07-2005, 08:23 PM
sofast's Avatar
sofast sofast is offline
Send a message via AIM to sofast Send a message via MSN to sofast Send a message via Yahoo to sofast
Need advice on swap
My friend swapped a D16Z6 into his 89 civic hatch with a 1.5. He used the original ecu (89 civic hatch) and tried to wire the injectors off of that ecu. Just as thought it didnt work. My advice was the ECU that controlled the D16z6 and the harness as well. Any advice?
Old 06-07-2005, 08:36 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
Re: Need advice on swap
do a search in this forum
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 06-07-2005, 08:38 PM
BLU CIVIC's Avatar
調整器
in case u didn't take my advice...i searched 4 u
http://www.automotiveforums.com/vbul...earchid=986156
The name's Adrian
2011 CR-Z - Stock
Old 06-07-2005, 08:51 PM
sofast's Avatar
I forgot to mention that he has a vtec head
Old 06-07-2005, 08:55 PM
sofast's Avatar
Re: Re: Need advice on swap
thanks
Old 06-07-2005, 09:02 PM
sofast's Avatar
The only thing I found was d16a to d16z swap. I need d15 to d16 with a vtec swap info. Wiring ecu or related info. Thanks
Old 06-07-2005, 10:02 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
you need to look in the FAQ at the top of this forum for a multipoint injection conversion. you need to do that conversion first just get that z6 to even start up, and thats if you use an OBD0 distributor, injectors, resistor box, and ECU. if you want to use the injectors, distributor, and ECU from the z6, you will need to additionally convert to OBD1
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
