Go Back   Automotive Forums Car Chat > Dodge > Avenger
Old 06-07-2005, 07:58 PM
pnelectric pnelectric is offline
Dodge Avenger Maintenance
I have Dodge Avenger 6V 1998. I want to change some things, because when I driving somthing in front is making noisy. Also when I driving on rough surface seems to be like loosing bottom. When i turning it make also noise. This happen in front of the car. Could You suggest me what i suppose to change in this car. Thank You
Old 06-08-2005, 11:32 PM
JackDaniels386 JackDaniels386 is offline
Re: Dodge Avenger Maintenance
try the shocks
Old 07-04-2005, 02:41 PM
mr.avenger's Avatar
mr.avenger mr.avenger is offline
Send a message via AIM to mr.avenger
well i actually have had the same problem and it was the shocks but it was also my ball jointsseperating from a long period of driving on rough roads with bad shocks sounds bad but its not too much to fix if your a diyselfer.
Old 07-05-2005, 08:26 PM
Thank You but I think that is more than a shock. It looks like I loosing some parts of the car. Thank You
Old 07-06-2005, 03:15 PM
mr.avenger's Avatar
Well i talk to a friend of mine whos a mechanic and hes said check your front sway bar he said he had a car come in once with a very simialar problem and the sway bar was disconnected just from high milage or even from hitting something in the road and what was happening was the sway bar was rattling under there from being disconnected... i dont know just tryin to help....
1995 DODGE AVENGER!
2.0 ltr. DOHC 420-a engine
Shaved door handles
Shaved gas filler tube(mounted in trunk)
Enkei demolisher 16" rims
Primer awaiting paint
Old 07-07-2005, 11:49 PM
I will look tommorow. Thank You for Your help
Old 07-09-2005, 11:39 AM
mr.avenger's Avatar
no problem i just know what a pain it is to have something wrong with your car an not knowing what it is lol
1995 DODGE AVENGER!
Shaved door handles
Old 07-19-2005, 02:07 PM
jmagin jmagin is offline
Just so you know, there was a recall in the late 90's for ball joint play/seperation. Dodge dealerships will still fix this for free, they just need to run the VIN number to see if it has been complied with yet. I believe they replace all of the ball joints. Call your local dealership.
Old 07-19-2005, 02:21 PM
I'm second owner. If it is still posible?
Old 07-19-2005, 03:18 PM
Re: Re: Dodge Avenger Maintenance
Yes, it is applicable to ALL Dodge Avengers. Regardless of who initially bought it.
