Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 06-07-2005, 07:54 PM
B33p3r B33p3r is offline
If you have strange electrical problems
Before you do anything else...Disconnect your battery! Clean the + and the - posts and the cables that attach to them. Check the chassis ground that goes from your batteies - post to the frame(chassis) and clean that too. Shiny metal to shiny metal is good. Rust and corrosion is not your friend.
I've followed alot of posts here that have transmissions in limp mode problems. Crawl under the vehicle with a haynes book in hand if need be, and check the solenoid connections to the trans. Clean the grounds for the solenoid! Check the wires for the solenoid! Too many trannys are rebuilt or replaced for big bucks because of a loose wire that was inadvertantly repaired during reinstall or a ground wire that was rusted.
get yourself an electrical diagram for your vehicle(www.alldata.com) and learn how to read it and save yourself alot of money. These diagrams tell you where the grounds are for all the components. Clean them. If you can't decipher the diagrams, copy and paste them into word and email it to me and I'll be happy to help. I hate to see people spend big bucks for parts swapping when the real problem is a loose or bad connection. "Never under estimate the value of a good visual inspection".
Remember all the battery voltage(sorry amperage) travels out the -(neg) post of your battery, through the frame(chassis), into the load(motor, light, coil of a relay, or switch, through a fuse, and back to you battery +. (pos) post.
Old 08-30-2005, 12:03 PM
jeff84red jeff84red is offline
trans/guages
I have a trans that shifts ok after the first 200 yards but not before. When i move the shifter from park to low 1, the battery guage needle fluxuates. Also the gas gauge doesnt work,,,,any ideas on grounds to check??
Old 09-28-2005, 05:40 AM
JOHN GIBSON JOHN GIBSON is offline
Re: If you have strange electrical problems
What Color Is The Lock Up Solinoid Wire On A91 Explorer A4ld.
