I just got an autometer Tach, one of them ones that mounts to the steering column..... How do I hook the damn thing up?
1970 Olds Cutlass S... Red w/ white stripes, 442 decklid Rocket 350 bored .30 over 10.5:1 Pistons, Eagle Rods Crank shaved 30 thou Edelbrock Olds 350 Preformer intake Shimmed oil pump Big Valves, Shaved heads, Roller Rockers Lunati strip Cam Flowtech Headers 3" purple hornies header pipes w/ turndowns Bosch Platinum 4 plugs w/ Accel 8.8 wires TH350 Tranny 3.73 rear, looking for spool or some sort of posi.... |
Re: Tach
follow the instructions.
Re: Re: Tach
If hes on the forum that usually means no directions...lol But you can have your way Geno...
91 RS Camaro V8 305 TBI cold/ram 14"/3" open element K/N filter 3.73's B&M Megashifter 180 thermostat Flowtech TERMINATOR Exhaust 3" exhaust cutout Silvania Silverstar Headlights Ronal R15 Firehawk Wheels Hankook Ventus Sport (front) Sumitomo HTR+ (rear) 275/40ZR 17 all around... _____________________________ |
Re: Tach
yea i know, it's only cuz I don't know the answer.
Re: Re: Tach
you crack me up!!!!
Re: Tach
damn nice whorage on this thread, but ill try to help jim out. lol i dunno if the nams jim just thought it would add a kick to my instructions. ok well jim there should be an igniton wire somewhere on the engine thats probably red (telling you from doing it on my bros elcamino wit a carbed 305 so it might be useless) with like silver stripes maybe and it should connect to a spot on the carb (if you have one) you splice that wire so it conects to itself and to the tach wire that goes to there and there might be 2 other wires on the tach that go to positive and negative. umm thats pretty much it. if that dosnt help at all search online for instructions or wait for someone to tell you something better. actually crap i think the wire was on the distributer and the distributer will have the "ignition" labeled and you just connect the tach wire to that wire. it should plug into the disributer on the side. and im not sure but i think that wire goes to the carb but thats a guess from memory. but hope that helps.
87 firebird formula ws6 (currently has a old 78 305 with the following upgrades, including lots of miles and stock heads and internals....oops) crane cam cam specs performance valve springs and retainers, flowtech headers, 255 lph fuel pump, holley 600cfm carb, weiand single plane manifold, a healty diet. 14.90 1/4 mile....just wait for the 406 to be finished MY VIDEOS MY PICTURES -Tom |
Re: Tach
you will only have a wire on the carb if you have an electirc choke on it (probably a black circular thing on the passenger side of the carb). you need to connect three wires... i think only one is necessary: the tach wire. the tach wire is connected to the distributor and it sends the signal of how many revs your are doing. on most camaros this wire is white. if you don't have a white wire... it probably the one that is not black or red (there should only be a couple of wires on the distributor), maybe yellow. if you want to pull your instrument cluster out, the wire that goes to the original tach should be the same thing. the other to connections are for the power. one is a ground connection and the other is a accessory connection, this goes to a wire that is only hot when the car/ignition is turned on. you could connect this to the positive terminal of the battery (a red wire) but the light on the tach would be on all the time. i think the easiest way is to connect the ground and the acc to the wires on your radio. ground is black and acc (i believe) is orange. if you have an amp in your trunk, the acc wire is the same as the blue wire that runs to your amp.
90 Camaro RS V6 - swapped to V8 -350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft ESTIMATED 360-420 hp 380-430lb/ft torque
