Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 06-07-2005, 04:43 PM
tanguy28 tanguy28 is offline
Post no spark to cap
no spark to cap (replaced the coil and module ) now what should i try
Old 06-08-2005, 03:38 PM
Austin8214's Avatar
Austin8214 Austin8214 is offline
Re: no spark to cap
Need more info I.E. year, engine, ect.
Old 06-08-2005, 06:22 PM
LANDO10101 LANDO10101 is offline
Re: no spark to cap
IT IS DIFFICULT WITHOUT VEHICLE YEAR-MODEL-ENGINE SIZE-AND DETAILS ON EXACTLY WHAT HAPPENED WHEN YOU FIRST NOTICED THIS..HAS IT BEEN RUNNING ROUGH FOR AWHILE HAVE YOU DONE A RECENT TUNE UP ETC..?
I WOULD CHECK IGNITION FUSES AND RELAY.
AND TEST FOR POWER SUPPLY AT COIL..12 VOLTS..TRACE AND CHECK YOUR ECM GROUND.(NOT LIKELY THE PROB. JUST THROWING IT OUT THERE FOR YOU)
IS THE COIL PLUG WIRE BURNT HAVE YOU CHECKED IT FOR PROPER RESISTANCE??
GOOD LUCK
Old 06-13-2005, 01:47 PM
Re: no spark to cap
87 4.9 its getting power to the module but the at the top of the cap
