Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 06-07-2005, 04:32 PM
JackSchyitt619 JackSchyitt619 is offline
Send a message via AIM to JackSchyitt619 Send a message via Yahoo to JackSchyitt619
Arrow 96 2.4 2wd xtra cab no click no start?
The battery seems to be strong radio, headlights, dash ect.
I push it and it starts up and runs good. But it's time to get it right.
There's no starter turning or click when i turn the ignition key and i'm pretty sure i need to replace the solinoid contacts. How can I test the starter relay, do you need a certain tool to remove it. The fuses in the relay box and in the cab by the hood release are fine. The starters on the drivers side by the intake manifold anybody know the steps and tools needed?
Old 06-07-2005, 07:54 PM
Flash75 Flash75 is offline
AF - Advisor
Re: 96 2.4 2wd xtra cab no click no start?
You can read how to repair your starter here;
http://www.4x4wire.com/toyota/maintenance/starter/
Clifton
Old 06-08-2005, 12:01 AM
Thumbs up Re: Re: 96 2.4 2wd xtra cab no click no start?
Clifton
That's very informative but I have a 96 2wd tacoma with the 16 valve 2.4 L 4cyl w/std trans. The starters on the drivers side. I hope I can get a reply or link for my truck. Thanks Clifton.
Old 06-08-2005, 07:07 AM
AF - Advisor
Sorry it didn't help. There is a 2003 Tacoma shop manual on line, I know you have a 96 but the procedure for stater removal may be the same on both trucks. I haven't found a source for other years.
http://fsm.afraid.org/
Go to Volume II and find Starting system 2RZ-FE,3RZ-FE.
Clifton
Old 06-09-2005, 12:54 AM
Clifton
Awesome ! Looks just like my setup. Thank you very much Clifton!!
