Old 06-07-2005, 04:29 PM
geoff.doctor geoff.doctor is offline
Send a message via AIM to geoff.doctor
Couple of Basic Questions
Just picked up a 89 Accord SEi 4 Door for $200. I think I got a pretty good deal as the body is decent, it has a perfect (and I mean perfect!) Leather interior, Rockford Fosgate deck, and seems to run ok.
Now I am having some issues with it. One is that at higher RPMs (4500+) It will sometimes put out white smoke, and sometimes if you open the hood when its running you can faintly see white smoke coming out from under the head. Probably a blown head gasket, right? If so, how hard is it to replace them, the part prices don't seem too steep.
Secondly, just today I noticed the battery (alternator) light was on. It goes off however if I hit the breaks, or turn the AC on high. This happend after I 1. Ran out of gas, 2. cleaned the engine.
Also, pulled the e-brake so I could get out and open the garage door, and the car didn't stop. It seems to engage it some, but will not hold the car on a hill.
Also just so you know if it makes a difference or not, there is no power steering belt on the car currently.
So you guys got any idea what could be causing these things?
Thanks!
Old 06-07-2005, 05:48 PM
94accordlx1 94accordlx1 is offline
Re: Couple of Basic Questions
the white smoke is a blown head gasket cost to fix 900-1200 dollars. I think some fuses might be mixed up or burned for the battery light, and the e-brake needs adjsuting or you need new rear brake pads or shoes.
Old 06-07-2005, 06:05 PM
900-1200? Parts are a lot cheaper. What is involved in replacing it myself?
Old 06-07-2005, 08:53 PM
AccordCodger AccordCodger is offline
Ah! I see I responded to the FIRST of your identical postings. Why DID you post the same question 2 1/2 hours apart? We're all volunteers here - a couple of hours is a very small amount of time to wait for a response.
{quote]I think some fuses might be mixed up or burned for the battery light, [/quote]
No, 94accordlx1, fuse problems won't do that. And what are "mixed up fuses."
Old 06-07-2005, 10:30 PM
The double was an accident, It said the page didnt send, so I reconnected later and tried again, sorry. Anyone know about teh head gasket replacement? There doesnt seem to be a loss of power, and its only every once in awhile. I was holding it at 5k rpms today with no smoke. Also there is no coolant in the oil.
Old 06-07-2005, 10:35 PM
Sounds like the (good) parts might be worth $200! You've got a passel of troubles there, boy, so I hope you don't mind putting a lot of sweat equity into the car, and maybe still not having it run right.
Head gasket? Maybe. But the head may be warped or cracked too. E-brake might be frozen cables, or just need adjustment. Or your rear brakes might be rusted up entirely!
No power steering belt? Why not? What's the matter with the power steering?
Your gen light problem MAY relate to your getting cleaning liquid on the belt and it's slipping now. But why INCREASING the load would make it go off again, I've no idea.
I think you bought a bag of someone else's bad maintenance.
Just to keep it all in the same thread. Also, car only has 129k miles, and im sure thats all original.
Old 06-08-2005, 07:12 PM
Update
No more gen light issue. It hasn't smoked on me at all today, and there is no coolant in the oil. The smoking is only when revved at higher RPMs, and it didn't even smoke when I did that today. The reason there is no power steering is that the pulley is broken, and so it keeps throwing the belts off. I have a new one so I need to get it installed.
Any thoughts on the head gasket?
Old 06-09-2005, 06:32 AM
That's good news. I hate to admit that cars "heal themselves" but I had an oil leak that did just that. My mechanic said it was a rear main seal (expensive) problem. With no other repairs, it just stopped. Now I never get a spot of oil in my driveway.
Old 06-09-2005, 09:06 PM
Another Update. Pulled the radiator cap, and the fluid is right where it should be up on top. However it is a rusty brown color. Does it just need a flush? Also this car did have an anti-freeze leak before I bought it in which it was repaired.
Old 06-10-2005, 08:11 AM
Yes - the system needs flushing.
Old 06-10-2005, 04:58 PM
lamehonda's Avatar
lamehonda lamehonda is offline
Have you tried Restore in the car? That help some of the smoke that I had in my 87 with 210K. And its pretty cheap.
1987 Honda Accord LX-Dead
1999 Honda Accord EX-L 5 sp-Sold
2006 Subaru WRX Wagon 5sp-Sold
2005 Nissan Frontier ext cab 4x4 4.0L-Sold
2006 Kawasaki Ninja 500r-Sold
2004 Yamaha FZ1 Silver/Black- Sold
2008 Mazdaspeed 3-In the driveway
Old 06-10-2005, 10:27 PM
Sorry if this is a dumb question, but what is restore? Also this car seems to be using an awful lot of gas. Does that have anything to do with the smoke?
Old 06-10-2005, 11:13 PM
lamehonda's Avatar
Restore is an oil additive that you can pick up at walmart. You only have to put it in when you change the oil and then every year or so. I was getting poor mileage at the time and I started getting 10 mpg better. Might work for you too. Keep me posted if you try it.
Old 06-11-2005, 07:14 AM
geoff.doctor - you said white smoke, right? An oil treatment won't help with that. Oil smoke is black.
Bad gas mileage (and it sounds like you have only guessed whether it's "bad" or not) could be any one of a number of things.
Are you SURE you don't want to just get rid of it and get a better one? You've got more problems at one time than I've had in all the 3 Hondas I've owned put together. We haven't even gotten around to asking you when the timing belt was last changed. Or whether the axles click when moving on full lock.
Old 06-11-2005, 08:10 AM
COdger, I am new to cars, and bought this one as a project. I want to experiment with it so I can learn how to do this stuff on my nicer car (Nissan Maxima SE). If I blow up the engine, I'll sell the leather seats and deck and get all of my money back.
