Old 06-07-2005, 11:48 AM
c-72 c-72 is offline
Question 93 S10 Blazer 4x4 problem (4WD problem)
My last post didn't have a descriptive enough subject title so I am reposting with a better subject. I am having a problem with getting my 1993 S10 Blazer's 4x4 switch to work. Basically the problem is that it won't activate. The lights come on on the switch when the key is turned to the on position but, it won't turn on when I actually hit the switch (hi or low). What are some common problems with this system? And where are things located that may need to be worked on or replaced? Thank you.
Old 06-07-2005, 01:14 PM
troy1 troy1 is offline
AF -Advisor
Re: 93 S10 Blazer 4x4 problem (4WD problem)
Switch bad, bad vaccum under the battery for the 4x4 diafram, switch on top of the t-case shot.
Old 06-13-2005, 10:40 PM
cherokee_guy82 cherokee_guy82 is offline
Send a message via Yahoo to cherokee_guy82
Agree with troy, I have a 93 also and my problem was a broken vacuum line on the diaphragm that engages the front axle. it is under the battery tray, so you may have to take it out to get to it
Friends don't let friends drive ricers!
'99 Dodge Ram 1500 Laramie SLT
'04 Monte Carlo LS
Old 06-18-2005, 03:17 PM
Pretty soon I will be removing the totally rusted out fenders on the blazer so, when I do that I will check that diaphragm. Thanks.
