Old 06-07-2005, 11:17 AM
Deadhead's Avatar
Deadhead Deadhead is offline
86 accord very hot....
OK, so i'm traveling from Loveland CO to Denver yesterday, and my car seems to get to about 7/8 up on the thermostat, but no further, while i'm in town, it doesn't go over 1/2. There is plenty of coolant in the reservoir and the radiator, I'm at a loss at what could possibly cause this. I was traveling 75 to 90 mph. So my RPM's were above 3,000 the entire time. The strange part is when i got down to rush hour, there were dead stops, and still it is very hot. Can you give me some ideas? and also walk me through the process of what could cause this excess heat. I am told that the car should never get over 1/2 way up.
thanks
1986 Honda Accord LX-i 5 spd
Completely stock... but i like it anyway, it's got a strong e-brake
www.cheesemit.us
http://www.cardomain.com/ride/862348/1
Old 06-07-2005, 11:25 AM
Igovert500's Avatar
blue + red light magnet
Re: 86 accord very hot....
Are your fans coming on? When is hte last time you replaced your thermostat?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 06-07-2005, 11:53 AM
94hondaacc 94hondaacc is offline
i would think its your thermostat not opening. you should have it changed. you might want to flush your radiator too just to make sure that doent get clogged either.
Old 06-07-2005, 11:55 AM
Deadhead's Avatar
The fan's do come on, and i haven't had the car for more than 7k miles.
Could the thermostat be the cause?
www.cheesemit.us
Old 06-07-2005, 02:35 PM
Deadhead's Avatar
http://www.autopartsworld.com/1986_h...tat_parts.html
is this the piece that i need? and is it just on the intake manifold?
www.cheesemit.us
Old 06-08-2005, 08:59 AM
yeah that s the part. its supposed to open when the car reaches a certain temp, to allow the car to cool down, problem is after a while it might get stuck, causing the car to overheat, thats why this is most likely the problem, since the fans go on.
Old 06-08-2005, 11:08 AM
Deadhead's Avatar
ok, thanks a lot.
I appreciate all the help you guys give me....
THANK YOU!
www.cheesemit.us
Old 06-09-2005, 01:18 AM
94 Accord 94 Accord is offline
It can be the thermostat. Also is there anyway you can find out when was the last time ur water pump was changed? The bearings could possibly be worn in ur water pump.
Old 06-09-2005, 06:40 AM
AccordCodger AccordCodger is offline
Worn pump bearings wont have much, if any, adverse effect on the cooling itself. They'll make a racket and probably leak all over the place instead.
Old 06-09-2005, 03:54 PM
Deadhead's Avatar
Is there anything i need to do when replacing the thermostat? is it just a simple unscrew and screw on type thing?
www.cheesemit.us
Old 06-10-2005, 08:10 AM
Bleed the cooling system after you're done.
Old 06-11-2005, 04:22 PM
Deadhead's Avatar
ok, after looking at other threads... i see that when the thermostat is having a problem, it's also in Town driving. The ONLY time mine get's hot, and it doesn't even overheat, is when i am driving on the Highway. Can someone explain to me why this happens?
I just looked at my car and let it idle and again, it wouldn't go above 1/2. I also drove it around, again, no problems.
Is there a reason for it only getting hotter than normal when i'm on the highway?
www.cheesemit.us
Old 06-11-2005, 05:05 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
If the thermostat is sticking only partly open, or the radiator is hogged up with crud, there isn't enough coolant movement to keep up with the additional heat the engine is producing at higher revs. So the faster you go, the quicker and harder it'll heat up.
At idle, and lower speed, the volume of coolant moving past the restriction may be sufficient.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 06-11-2005, 05:08 PM
Make sure you aren't missing a deflector underneath also. Cars now with their very small grille openings depend mostly on directed air from under the front to cool the radiator. If you knock one off, you can't get enough airflow at highway speeds.
...empty gun rack.
Old 06-11-2005, 06:37 PM
Deadhead's Avatar
Re: Re: 86 accord very hot....
So what your saying is that it could be my Radiator OR my thermostat.... right? If it is the Radiator, how would i tell if it's got a lot of crud in it?
www.cheesemit.us
