Go Back   Automotive Forums Car Chat > Chevrolet > Nova
Old 06-07-2005, 10:10 AM
Gilmore03 Gilmore03 is offline
Oil leaking onto headers???
I just dropped in a brand new 350 from chevy into my 74....I put about 100 miles on it, and its already leaking bad...I cant tell if its coming from the heads or not, but its dripping on the headers and smokeing bad. The starter is also soaked in oil it looks like.
Old 06-07-2005, 10:33 PM
72_supernova 72_supernova is offline
I would take it back to chevy and try to get them to fix/replace it. good luck.
Old 06-08-2005, 07:57 AM
Robs71Nova's Avatar
Robs71Nova Robs71Nova is offline
Send a message via AIM to Robs71Nova Send a message via Yahoo to Robs71Nova
Oil is not going to leak from your actual heads.. Make sure your valve cover gaskets are not leaking.. that is probably the problem..
Rob
Old 06-08-2005, 11:02 PM
Greenboy25 Greenboy25 is offline
Re: Oil leaking onto headers???
Also check the oil pressure sending unit
Old 06-10-2005, 05:01 PM
Even if your valve cover gaskets are in good condition if the lip on the valve cover is tweeked or is not smooth and flat then that could cause leaks.
Old 06-13-2005, 12:33 PM
its deff not the valve covers, cause i would be able to see it leak...i cant see the leak. I dont know how it could be the head gasket because the headers are a little above where the heads meet the block. I cleaned off the headers where the oil has dripped on to it, so when i started it up again i could see where is dripping from, but i cant see nothing.
Old 06-24-2005, 07:19 PM
v8fieroman2003 v8fieroman2003 is offline
it may not drip were you can see because its not leaking just sitting there running, clean it good and drive for about 10min and then check and i would almost put money on the fact that its the valve covers or gaskets
