Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 06-07-2005, 08:29 AM
mjhok mjhok is offline
Question 95 Explorer Power windows & interior lights
None of the power window switches are getting power. All the interior lights are out too. I've checked for broken wiring in the door harness none there. I've disconnected and connected the battery, no help.
I've read online about two relays to change, one is FOAZ14N089A, Brkt Asy-Rly Mtng and Accy delay Relay module #4.
WHERE ARE THESE TWO RELAYS LOCATED? I can't find them. Also, any other suggestions? Thanks Mike
Old 06-07-2005, 08:55 AM
B33p3r B33p3r is offline
How did you check your wiring? Visual inspection? That's the best way to start! But did you follow up with a Voltmeter? 12 volts at switch? 12 volts on switch supply? If you have no voltage at switch, wiring diagram tells you what the previous test point should be. I don't have a diagram for a 95 so I'm not much help beyond that. WWW.alldata.com for $19.00. Good for a year. And if you have the patience, copy and paste the diagrams into word and when done burn onto a CD.
Old 06-07-2005, 10:21 PM
Re: 95 Explorer Power windows & interior lights
Hey B33p3r. Thanks for your post. Yes I did a visual but since the interior lighting is involved I figured it was some sore of relay or something. I changes the accsy delay-power window relay (4bucks at O'reillys) But it didn't help. Finally I've just done a temporary fix by splicing a hot wire from the power mirror switch to the power window blue black wire. Having gotten power to that unit I can now work all the windows
However, the interior lights still don't work and I'd forgotten to mention that the radio stopped some time ago. It gets power to the display but makes a low barely audible voice sound when turned up. I don't know if this is another relay or mixed up in the whole thing. This all started when i messed with the door panel to fix the handle. Also, I had just fixed the right headlight being out by resoldering parts of the Lamp Outage Module. So, fixing one thing I screw up another, I guess.
I'm not giving up, so any other suggestions? Why would the interior lights go out with the power windows unless there was some integral connection between the two? Thanks for your help. Hark
Old 06-08-2005, 12:27 PM
FIXED IT!!! Windows wouldn't roll up again so I figured the the hot wire i ran shorted something because now the power mirrors wouldn't run. So I checked the fuse box and #27 interior lights was blown and #1, the power mirrors was blown.
So get this, when i changed those fuses, the power windows started working fine again!!!!!!
So check all the fuses with a visual regardless of what they are marked because it fixed my windows power loss. Go figure.
