Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 06-07-2005, 07:36 AM
chris1 chris1 is offline
Unhappy what motor should I use.
Hi people,
I just purchased a 1995 Pontiac Transport for the low price of $50.00. The motor was gone in the van, it had a 3.1 L. I am getting mixed messages/comments about the motors. should I go with another 3.1 or should I upgrade to a 3.8 instead. We will be doing a lot of travelling with the van so I want something that is good on the highway as well as good on fuel. If I do upgrade is there a big process involved in doing this. Any help would be great on this topic. Thanks very much. Chris
Old 06-07-2005, 08:02 AM
cdru's Avatar
cdru cdru is offline
Re: what motor should I use.
Was anything else missing or just the motor? Based off of what others have said here in the past, if you upgrade engines you are also going to have to change the tranny, wiring harnesses, PCM, etc. It's not just the engine that you are swapping.
Old 06-08-2005, 07:09 AM
timguyli timguyli is offline
My 95 has the 3.1 and other then the wonderful head gaskets going...... its been a great engine. Not as peppy as the 3.8, but not that bad. I recommend if you use a replacement 3.1, redo the head gaskets before installing it back into the van.
