2000 3.5 V6 Help - UPDATE
Cracked head at cyl #3 at only 37K mi. It's out of warranty so a local shop with a very good rep replaced the head. They had some problem setting timing until they found the TSB on timing belt. BUT, now it has a flashing CEL, code is mis-fire cyl #4 - lean (not the replaced head, the other side they didn't touch). Also Random Mis-fire code at times.
They reset the timing belt numerous times, swapped plug, coil,and even injector between cylinders but error stays at #4. They're at their wits end, anyone have an idea ? Thanks.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs 80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ... 89 4Runner - stock 2000 Isuzu Trooper + 2010 Sonata Last edited by fourwd1; 06-27-2005 at 12:42 PM. |
Re: 2000 3.5 V6 Help
could be a crack intake manifold gasket. this will give a misfire code and it very common. See the FAQ's for more info.
-Ryan Isuzu Moderator Car Show Tips Operations manager with a results-driven passion for process improvement FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd |
Thanks
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs 80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ... 89 4Runner - stock 2000 Isuzu Trooper + 2010 Sonata |
Did they replace the spark plugs? If so, what brand did they use? Non-denso spark plugs will give you a flashing (misfire) CEL on the 2000+ 3.2/3.5's
G/luck Joel
2016 Subaru Forester 2.5i base CVT 2016 Nissan Quest SV |
Update
Long story short, the coil assy on cyl #6 is slightly different from cyl 1-5. Cyl 6 coil ended up on another cyl during re-assy of engine. Specific cyl misfires don't get logged, only show up while driving, so it was missed until he took it for a drive with the scanner on, instead of reading the codes afterwards.
