Old 06-07-2005, 02:32 AM
rounder rounder is offline
help me out with with my options
ok so I found out that my #3 cylinder has no compression. and that can mean new compression rings. which means a lot of money.
the options Ive been given
1. trade it in and get a different car
2. pay to get the rings replaced
3. pull the engine and either get it rebuilt or drop another one in.
option 3 is in my head but Its gonna cost a lot of money and I don't even know where to look for another block. and I also have to see if i can make due with a short block or if I will have to get a long block.
any suggestions will help. thanks
1992 Eagle Talon TSI
FWD
Automatic
Old 06-07-2005, 04:19 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: help me out with with my options
If by "no cpmpression" you mean ZERO compression, it is much much more likely to be a problem in the head. Much easier and cheaper to fix It would help if you could be more specific and post the actual numbers, instead of a generalization.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 06-07-2005, 11:59 PM
um so the mechanic said # 3 cylinder had 20 pounds and the rest had 70 or 80 pounds.
the engine runs really rough and you can tell that its missing. so I did the plug check and pulled off #3 and the car idles the same. so thats just saying its gotta be #3
FWD
Automatic
Old 06-08-2005, 01:27 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
70-80 is still a very low pressure for a cylinder. engine swaps aren't too terribly tough, and they're kind of fun too. if you like working on shit, i would say try out the engine swap and drop in another 6-bolt.
if it's just the rings that are bad, you should be able to get by with just a shortblock and using your old head, but it all depends on what is leaking. have your mechanic do a cylinder leakdown test to see where you're losing compression.
95 Talon TSI AWD
97 Eclipse GST
Old 06-08-2005, 02:56 PM
AF - Advisor
With those numbers it could even be a really bad HG. If this was my car, I would pull the head first to get a look at the gasket, and the pistons/cylinder walls. The can be off in an hour or two, and can answer some questions. From there, pulling the motor isnt hard, most of the work is done.
Kevin Jewer
